Pocket GPS World :: View topic - i3 USB drivers won't install on Win XP SP2
shadowritten
PostPosted: Sun Nov 20, 2005 2:18 pm    Post subject: i3 USB drivers won't install on Win XP SP2 Reply with quote
Hi there - first post!
Been searching this site for help with USB driver installation, but without success. I've tried everything: the correct procedure using the CD-ROM just doesn't work, nor does any workaround (I'm reasonably technically/IT competent).
Anyone think of why the USB drivers just won't install? The folder for Garmin appears in C:\, all the files appear to be there, I can point the Add Hardware wizard at these files, but after quickly searching WINDOWS\System32\Drivers, it just says device cannot be installed correctly.
Do I have faulty i3?
Cheers!
RODTROTTER
PostPosted: Sun Nov 20, 2005 2:58 pm    Post subject: Reply with quote
right click on my computer
pick properties pick hardware
pick device manager
look for any device class ie a red sight then click on it and update drivers that works most time with this sort of thing
shadowritten
PostPosted: Sun Nov 20, 2005 4:40 pm    Post subject: Reply with quote
Followed you all the way up to this bit above, then couldn't figure out what you meant! Embarassed
Device class? You mean one of the device type categories, yes? A 'red sight'? Not sure what one of those is, sorry!
When I have the Garmin i3 plugged into the USB, I can see it in Device Manager. But any attempt to update drivers is met with a dialog box telling me that's a no go - that the device will be uninstalled following the next restart.
Any other tips? (Thanks for replying to this one, by the way :D )
Trajet
PostPosted: Sun Nov 20, 2005 4:44 pm    Post subject: Reply with quote
Try Downloading from the Garmin web site.
http://www.garmin.com/support/collection.jsp?product=010-00434-00
shadowritten
PostPosted: Sun Nov 20, 2005 4:53 pm    Post subject: Reply with quote
Yep, tried that, too!
This is crazy. I've never had a single driver fail to install on my PC before ... Rolling Eyes
zogman
PostPosted: Sun Nov 20, 2005 5:07 pm    Post subject: Reply with quote
have you tried a reboot of your pc..
RODTROTTER
PostPosted: Sun Nov 20, 2005 5:31 pm    Post subject: Reply with quote
sorry i ment device clash
RODTROTTER
PostPosted: Sun Nov 20, 2005 5:33 pm    Post subject: Reply with quote
have you installed the poi uploader that may help
shadowritten
PostPosted: Sun Nov 20, 2005 8:12 pm    Post subject: Reply with quote
Yep, several reboots, still no joy.
Can't even run the autoupdater thingy, as it doesn't recognise the i3 without the USB drivers installed!
This is maddening!!!! Evil or Very Mad
shadowritten
PostPosted: Sun Nov 20, 2005 8:14 pm    Post subject: Reply with quote
No device clashes showing up. It must be either a software problem or an issue with the innards of the device.
MELennium
PostPosted: Sun Nov 20, 2005 9:59 pm    Post subject: Reply with quote
Hi shadowritten
Could you explain exactly what is happening?
What are you trying to do exactly?
Have you installed the Garmin poi loader?
shadowritten
PostPosted: Mon Nov 21, 2005 12:50 am    Post subject: Reply with quote
MELennium wrote:
Hi shadowritten
Hi there
When I try to install the USB drivers - either from the supplied CD or downloaded from the Garmin site - I get as far as the Found New Hardware wizard, at which point I select the Automatic install (or try to search for drivers manually - makes no difference which route I choose), I get a screen telling me the PC is looking for drivers, then an error message says that the device drivers can't be properly installed. At which point, I click Finish, and the whole process begins over until I disconnect the i3 from the USB cable.
I tried to download the Webupdater from the Garmin site. It installed - but without the USB drivers working correctly and recognising the i3, the Webupdater can't see the device. Odd thing is, the Garmin drivers folder is there in C:\ ... so what am I doing wrong?
I haven't tried to download and install the POI loader yet. Does this have a bearing on the USB driver installation?
RODTROTTER
PostPosted: Mon Nov 21, 2005 1:43 am    Post subject: Reply with quote
dont plug in the i3 till you have installed the usb drivers i know it sounds silly but some things wont work if you plug in too soon
shadowritten
PostPosted: Mon Nov 21, 2005 2:26 am    Post subject: Reply with quote
Yeah, this I know.
I downloaded AND installed (or so I thought, perhaps?) the USB drivers from the Garmin Website. Plugged in the i3 - no joy! I inserted and ran the supplied CD ... it actually ASKED me to plug in and power up the i3 BEFORE drivers could be installed! So this I tried, and again, nothing.
I've lodged a technical enquiry on the Garmin site. If I get an answer, I'll post it here in case anyone else faces the same issues.
My thanks to everyone who's tried to help so far. Thumbs Up
MELennium
PostPosted: Mon Nov 21, 2005 8:35 am    Post subject: Reply with quote
Yes it should make a differerence as i believe this installs the driver and then your i3 will be found.
