Pocket GPS World :: View topic - Wrong position on road for Home Postcode ?
jonno2004
PostPosted: Sat Nov 19, 2005 11:29 pm    Post subject: Wrong position on road for Home Postcode ? Reply with quote
Hi All, as a very new user to TomTom 5 Nav software, I'm a little confused about my home Postcode. Basically it thinks that my house/home is at the wrong end of the road, so it always says I'm some 200mtrs away! Is there any way of telling the software that i live in the correct place or is it best just to use the 'crossing' function ?
Thanks for any replies in advance.
John
Ako
PostPosted: Sun Nov 20, 2005 12:15 am    Post subject: Reply with quote
This may not solve it but may get around the problem. Drive to your house with the nav program running and when you get there save your current position as home.
Holux231, XDAII Copilot 6, 1Gb Lexar SD Card
PostPosted: Sun Nov 20, 2005 12:19 am    Post subject: Reply with quote
Or stand at your front gate and do the same. Wink
Ako
PostPosted: Sun Nov 20, 2005 12:44 am    Post subject: Reply with quote
That depends on what software you're using Wink . Or maybe he could tell you when he invites you.
PostPosted: Sun Nov 20, 2005 10:06 am    Post subject: Reply with quote
Try creating a new category, saving the location to it, and emailing any visitors (with sat nav) the POI file. POIConverter can change it as necessary.
Navigation to the front gate. Smile
neil01
PostPosted: Sun Nov 20, 2005 1:34 pm    Post subject: Reply with quote
Thinking a little laterally, I wonder how long it will be before people start adding lattitude and longditude to their addresses. These can often be added directly to the various navigators, or converted to a suitable format by various freeware utilities.
Just to point out, while 7 digit postcodes are a great help, they do tend to refer to a number of houses, so without a house number you can only be directed to the area (unless of course you are going to the actual position it uses)
It is many years since I worked on systems using postcodes, but if I remember correctly, some of them (especially those for businesses or institutions) don't refer to their actual location, but to the location of the PO Box, so don't be suprised if you find that the poscode after a PO Box address isn't found - this woul be the correct action.
I would also imagine that since the Postcode file and the map data are from separate sources, they are never totally in sync, and that to prevent a system crash if the street is not found, the postcode location is simply a single co-ordinate which appears on the map. On new properties, I would quite expect it to be in the middle of a field.
jonno2004
PostPosted: Sun Nov 20, 2005 3:24 pm    Post subject: Reply with quote
Well thank you very much for all those answers, i'll try the standing at the gate test a little later. As for the bacon sarrny, maybe next time Laughing
PaulSB
PostPosted: Wed Nov 23, 2005 7:08 pm    Post subject: Reply with quote
I have a PO Box for an organisation I help to run and the postcode is the same as my home address. When I queried this with the post office it was explained the post code is used to identify me as the addressee but instead of delivering the mail they simply sort it into the the PO Box (well it's a filing cabinet in fact!).
While I'm not an expert I'm not sure Neil's point is correct.
neil01
PostPosted: Wed Nov 23, 2005 7:32 pm    Post subject: Reply with quote
As I said 'if I remember correctly', but that aside, I was dealing with very large businesses and institutions which often had multiple premises. While I do not dispute the fact that your POBox was the same postcode as your home, for many of these businesses or institutions, the place you would visit was often not the same as the location for the office.
The point I was trying to make was that the Post Code for a PO Box MAY be unreliable, sorry I should have been clearer.
mugwump
PostPosted: Sun Nov 27, 2005 8:11 pm    Post subject: Reply with quote
I believe you are indeed correct.
Take the Savoy Hotel London as an example. The Savoys own website lists its postcode as WC2R 0EU. This is a PO Box and some sat navs / streetmap.co.uk dont resolve this to the actual position of the hotel though they will get you closeish (because they will at least get you to WC2R!).
The *actual* postcode for the Savoy (if you want to navigate there) is WC2R 0BP.
Apologies to all my supporting users, the http://ukpostcodes.boldlygoingnowhere.org/ postcode converter has now been retired.
The ubiquity of full postcode lookups has made it somewhat redundant. I still have the code if anyone needs it.
22.063 (19 Jun 24)
