Pocket GPS World :: View topic - Faulty I3?? - Powering off
mentm
PostPosted: Sat Nov 05, 2005 8:00 pm    Post subject: Faulty I3?? - Powering off Reply with quote
I have just brought an I3 from argos which I have updated to version 2.7, and I have loaded speed camera POI from this site. I used nimh batteries and this was set to nimh in the settings.
After testing it out on a journey it turned it self off three times for apparently no reason in the space of two hours.
Is this unit faulty?? or is there something I am missing??
Many thanks in advance
mentm
awalsh
PostPosted: Sat Nov 05, 2005 9:52 pm    Post subject: Reply with quote
I've had two units that have done the same, well, one that turned off randomly whilst navigating and one that turned off randomly when using the menu's.
I would take it back
Garmin i3 | Orange SPV M500 with TomTom 5.10
gcb
PostPosted: Wed Nov 09, 2005 4:07 pm    Post subject: Reply with quote
Unsure about this but:
Look at the POIs you loadeed,
If you load 24bit speed camera POIs theres a chance it will switch off when it attempts to display them.
I converted all the POI images I use to 8 bit (256 colour). Absoloutely no switching off ever since.
zogman
PostPosted: Wed Nov 09, 2005 4:20 pm    Post subject: Reply with quote
if you got MaFt's poi's loaded you should'nt have any problems displaying them...it might be the v2.70 firmware which is reported to be a bit buggy..try going back to version 2.50...
mentm
PostPosted: Fri Nov 18, 2005 1:19 pm    Post subject: Reply with quote
thanks for the advice guys, I exchanged it for another unit and is now fine. Upgraded to v2.7 and added POI's with no problem. Must just have been a faulty unit.
Only problem now the new unit has map v7 Evil or Very Mad
PostPosted: Fri Nov 18, 2005 2:51 pm    Post subject: Reply with quote
if your original one had map version 8 on it then i'm sure you can go back to the shop and complain that they exchanged it for an out of date product and not 'like for like'
