Pocket GPS World :: View topic - TomTom Go External Antena
stodge
PostPosted: Tue Nov 15, 2005 5:07 pm    Post subject: TomTom Go External Antena Reply with quote
I have just bought a Go 300 hoping to be able to mount it into a compartment in the dash. The unit itself fits perfectly but obviously looses signal. I probably have an extra 5mm of height to play with which isn't enough for the standard external antena base.
Are there any antena's that work from the usb port (probably a stupid question) or has anyone performed a mod to make the mount slimmer?
PostPosted: Tue Nov 15, 2005 5:20 pm    Post subject: Reply with quote
Definitely not through USB.
The antenna connection on the base could be used, but getting hold of the mating connector is not easy and needs crimping onto the cable with special (expensive) tooling.
Your perfect solution sounds like a re-radiating antenna, which collects the signals, then re-transmits them inside your car.
Try a search on here and the Mytomtomgo forum as it has been discussed and I seem to remember someone offered a link or a model number.
stodge
PostPosted: Tue Nov 15, 2005 7:17 pm    Post subject: Reply with quote
Andy
Thanks for the advice. I've found a link to somebody who had the same problem with the same car and the re-radiating antenna did the trick.
Thanks again
nazimyounis
PostPosted: Tue Nov 15, 2005 7:21 pm    Post subject: Reply with quote
stodge wrote:
Andy
Thanks again
i am having the same problem, would you mind if i asked nicely were u found the link... thanks in advance.
regards
Nazim
TomTom ONE V2 (GB) Downloaded Europe Maps
Transcend 2GB Hi-Speed 150X SD card
ex - TOMTOM Nokia N95
ex - TOMTOM GO 700
ex - TOMTOM Navigator 5 on XDA IIi
ex - TOMTOM Navigator 3 on XDA II
Stanley_Tweedle
PostPosted: Tue Nov 15, 2005 8:01 pm    Post subject: Reply with quote
I think this is the thread I've seen before on this subject:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=27573&highlight=antenna+review
and this was the link to the antenna
http://www.gpsw.co.uk/details/prod444.html
Thanks to MrRusty for posting the original review!
stodge
PostPosted: Tue Nov 15, 2005 11:58 pm    Post subject: Reply with quote
Nazim
This was the actual link I saw specifically for the 350Z but you guessed it. Stanley was the man with the answer.
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=29551&highlight=reradiating+antenna
I am still waiting for a reply but i'm sure the other link points to a good unit.
Steve
22.094 (25 Sep 24)
