JimmyTheHand Frequent Visitor
Posted: Sun Nov 13, 2005 10:22 pm Post subject: 300 - No GPS Device |
My TomTom 300 is displaying "No GPS Device" - tried Reset, tried different SD card (the original) even reset to factory defaults – no joy. – It has been working OK for several months, but I lent it out to someone and from what I can gather it just stopped.
Any suggestions or is it back to TomTom _________________ J. |
TheWintonWanderer Occasional Visitor
Posted: Mon Nov 14, 2005 12:09 am Post subject: Tom Tom Go 300 No GPS Device |
I've also experienced the same problem as Jimmy the hand.
It stops at a blue screen and bottom LH corner shows 'NO GPS Device'
Occasionally I can get it to a menu screen and it will find satellites on the configure GPS screen but after a second or two out of this screen it will revert back to 'No GPS Device'
Anyone out there got any ideas - my Tom Tom's only two weeks old, should I be worried ? |
sparkey Regular Visitor
Joined: Jul 01, 2005 Posts: 185 Location: Pembrokeshire
Posted: Mon Nov 14, 2005 11:36 am Post subject: |
if i were you TheWintonWanderer i would bring the tomtom back to the shop.
As for jimmythehand someone with answer will help you out. |
sgould Frequent Visitor
Posted: Mon Nov 14, 2005 11:58 am Post subject: |
The symptoms you describe are those of a weak signal. Are you trying this indoors? Are you trying it inside a car with a heat reflecting windscreen?
Have you looked at the signal strength screen? From front screen touch bottom right corner. On next screen touch the satellite bars on the right hand side. Next screen shows grey bars and dots. The dots should turn to grey bars and then the grey bars should increase in size and turn blue. When you have three blue bars you have a lock.
If not it could be a faulty unit. Take it back. _________________ TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps |
Posted: Mon Nov 14, 2005 8:57 pm Post subject: |
sgould wrote: | The symptoms you describe are those of a weak signal. Are you trying this indoors? Are you trying it inside a car with a heat reflecting windscreen? |
It is connected to the external Aerial (where it has been working OK for several months). I have tried it where it would normally pick up a signal no problem - but no joy
sgould wrote: | Have you looked at the signal strength screen? |
Yes - no signal shown, and a message "No GPS Device"
sgould wrote: | If not it could be a faulty unit. Take it back. |
It has been working OK for months (I got it when the 300 was released). What I am wondering is whether a completely flat battery killed has killed a setting somewhere? (The person I lent it to had problems turning it off - it was taking a long time to respond) _________________ J. |
Posted: Tue Nov 15, 2005 9:30 pm Post subject: |
Quote: | You are at call position 5 - for faster response you could always use the web help pages |
No I can't use the [censored] web pages - they keep returning internal error - please try later
Quote: | Horrible music interuptted by You are at call position 5 |
20 minutes later
Quote: | You are at call position 1 |
God I hope the programmer remembered that the real world starts counting at 1 and not 0
Quote: | Can I help you - discussion resulting in a return number | _________________ J. |
Darren Frequent Visitor
Posted: Tue Nov 15, 2005 9:46 pm Post subject: |
Have you tried it off the external antenna mount? It may be a problem with that? _________________ Darren Griffin |
Posted: Tue Nov 15, 2005 10:06 pm Post subject: |
Darren wrote: | Have you tried it off the external antenna mount? It may be a problem with that? |
yes - I don't think it is to do with the external aerial (though I will be checking the cable before reconnecting the unit) _________________ J. |
Eldar Pocket GPS Moderator
Posted: Wed Nov 16, 2005 9:03 pm Post subject: |
"No GPS Device" means no communications between the motherboard and the receiver. Coluld be either an internal flexi cable problem or a dead receiver. |
Posted: Wed Nov 16, 2005 9:52 pm Post subject: |
Eldar wrote: | "No GPS Device" means no communications between the motherboard and the receiver. Coluld be either an internal flexi cable problem or a dead receiver. |
I assume that would explain the slow response when starting up - timeout while waiting for non-contactable GPS.
It is winging its way back to TomTom at the moment - so hopefully I'll get it back after all the 5.4 problems are identified and resolved _________________ J. |
Posted: Fri Nov 25, 2005 11:31 pm Post subject: |
Update
Got it back (a replacement anyway) from TomTom in less than 10 days _________________ J. |
