Pocket GPS World :: View topic - 300 - No GPS Device
300 - No GPS Device
JimmyTheHand
PostPosted: Sun Nov 13, 2005 10:22 pm    Post subject: 300 - No GPS Device Reply with quote
My TomTom 300 is displaying "No GPS Device" Sad - tried Reset, tried different SD card (the original) even reset to factory defaults – no joy. – It has been working OK for several months, but I lent it out to someone and from what I can gather it just stopped.
Any suggestions or is it back to TomTom
J.
TheWintonWanderer
PostPosted: Mon Nov 14, 2005 12:09 am    Post subject: Tom Tom Go 300 No GPS Device Reply with quote
Confused
I've also experienced the same problem as Jimmy the hand.
It stops at a blue screen and bottom LH corner shows 'NO GPS Device'
Occasionally I can get it to a menu screen and it will find satellites on the configure GPS screen but after a second or two out of this screen it will revert back to 'No GPS Device'
Anyone out there got any ideas - my Tom Tom's only two weeks old, should I be worried ?
sparkey
PostPosted: Mon Nov 14, 2005 11:36 am    Post subject: Reply with quote
if i were you TheWintonWanderer i would bring the tomtom back to the shop. Sad
As for jimmythehand someone with answer will help you out.
sgould
PostPosted: Mon Nov 14, 2005 11:58 am    Post subject: Reply with quote
The symptoms you describe are those of a weak signal. Are you trying this indoors? Are you trying it inside a car with a heat reflecting windscreen?
Have you looked at the signal strength screen? From front screen touch bottom right corner. On next screen touch the satellite bars on the right hand side. Next screen shows grey bars and dots. The dots should turn to grey bars and then the grey bars should increase in size and turn blue. When you have three blue bars you have a lock.
If not it could be a faulty unit. Take it back.
TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps
JimmyTheHand
PostPosted: Mon Nov 14, 2005 8:57 pm    Post subject: Reply with quote
It is connected to the external Aerial (where it has been working OK for several months). I have tried it where it would normally pick up a signal no problem - but no joy Sad
Yes - no signal shown, and a message "No GPS Device"
It has been working OK for months (I got it when the 300 was released). What I am wondering is whether a completely flat battery killed has killed a setting somewhere? (The person I lent it to had problems turning it off - it was taking a long time to respond)
J.
JimmyTheHand
PostPosted: Tue Nov 15, 2005 9:30 pm    Post subject: Reply with quote
You are at call position 5 - for faster response you could always use the web help pages
No I can't use the [censored] web pages - they keep returning internal error - please try later Twisted Evil
Horrible music interuptted by You are at call position 5
Evil or Very Mad Twisted Evil Evil or Very Mad Twisted Evil Evil or Very Mad Twisted Evil Evil or Very Mad Twisted Evil Evil or Very Mad Twisted Evil Evil or Very Mad Twisted Evil Evil or Very Mad Twisted Evil Evil or Very Mad Twisted Evil Evil or Very Mad
20 minutes later
You are at call position 1
God I hope the programmer remembered that the real world starts counting at 1 and not 0
Can I help you - discussion resulting in a return number
Smile
J.
PostPosted: Tue Nov 15, 2005 9:46 pm    Post subject: Reply with quote
Have you tried it off the external antenna mount? It may be a problem with that?
JimmyTheHand
PostPosted: Tue Nov 15, 2005 10:06 pm    Post subject: Reply with quote
yes - I don't think it is to do with the external aerial (though I will be checking the cable before reconnecting the unit)
J.
Eldar
PostPosted: Wed Nov 16, 2005 9:03 pm    Post subject: Reply with quote
"No GPS Device" means no communications between the motherboard and the receiver. Coluld be either an internal flexi cable problem or a dead receiver.
JimmyTheHand
PostPosted: Wed Nov 16, 2005 9:52 pm    Post subject: Reply with quote
I assume that would explain the slow response when starting up - timeout while waiting for non-contactable GPS.
It is winging its way back to TomTom at the moment - so hopefully I'll get it back after all the 5.4 problems are identified and resolved Smile
J.
JimmyTheHand
PostPosted: Fri Nov 25, 2005 11:31 pm    Post subject: Reply with quote
Update
Got it back (a replacement anyway) from TomTom in less than 10 days Smile
J.
22.064 (26 Jun 24)
