johnny3 Occasional Visitor
Posted: Sat Nov 12, 2005 8:40 pm Post subject: can anyone help me with this please, loosing connection prob |
Hi Guys, I have an Ipaq 2210, its been on a hard wired GPS receiver for ages and works like a charm, I thought i would get a wireless receiver so the misses could use it in her car as well..
Its a BT 77 wireless receiver, i have followed all the set up instructions and I get the ipaq to connect up, however i cannot seem to get it to be seen by the TOM TOM 5 software, it just says no GPS device, also the connection between the ipaq ans the BT77 only last for 2 mins and 20 seconds and then cuts out.
Ive tried a hard reset on the Ipaq and a fresh install of TOM TOM 5, still no go..
Can anyone give me a pointer please on what to do, or if ive missed something out.
TIA
John |
Posted: Sat Nov 12, 2005 9:03 pm Post subject: |
Jonney, go to prefferances, GPS set-up and select the Other wired NMEA devices option, set the correct Baud speed and finally select the applicable bluetooth port on the last screen, then make sure the set-up has a clean line of sight to the sky and wait, it can take upto 30 min for the sat nav to lock on to the info it requires - Mike |
Posted: Sat Nov 12, 2005 9:05 pm Post subject: |
thanks very much mikealder, what would the correct Baud rate be? or how could i find it, im really glad to have it working, thanks very much for the help |
Posted: Sat Nov 12, 2005 9:19 pm Post subject: |
The normal speeds that work are either 4800 or 9600, if you need to know the figure that is applicable to your device try the manufacturers web site it should be listed - Hope its all working now - Mike |
Posted: Sat Nov 12, 2005 9:38 pm Post subject: |
4800 mikealder, Thanks very much for the help, its working like a charm now |
Posted: Sat Nov 12, 2005 9:42 pm Post subject: |
Glad to hear you got it working - next you need the speed cams loaded up for security against getting a ticket, have a go its well worth the effort - Mike |
