Bigstoo Occasional Visitor
Joined: Nov 01, 2005 Posts: 29 Location: Republic of Yorkshire
Posted: Mon Nov 07, 2005 11:01 pm Post subject: |
british midland (bmi) are trialling non restricted gsm phone usage soon on their flights.
its the same with petrol stations and mobile phones, there has never ever been any instance of a mobile phone causing a fire (any one see brainiac? :p) |
Posted: Mon Nov 07, 2005 11:14 pm Post subject: |
What upset the petrol stations was the CB radio units, at the correct frequency when transmitting close to the pump you got more than you paid for (or so i am told ) the mobile won't cause the same problem as its low powered - on aircraft the wifi can cause problems - so keep the flight mode on and fly safe - mike |
Skippy Pocket GPS Verifier
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Tue Nov 08, 2005 3:06 pm Post subject: |
You can use GPS on planes, it works fine and I have done it dozens of times in a number of different aircraft types. Of all the ones I have tried it in (Airbus 318, 32X, Boeing 727/737/747/767/777, BAE146 etc) I have never found one where it didn't work.
The view out the window is limited so you have to hold the receiver against the window for it to work. It does take a while to get a fix, it helps if you have a good GPS fix within a few hours of boarding the plane. Make sure you get a good lock on all the visible sats before you go into the terminal building.
The GPS sometimes has trouble getting a lock at 37,000 feet and 600 MPH, be patient with it while it figures out what the hell is going on.
You are not supposed to use it (or any other electronic equipment) during takeoff and landing, although I have done this many times. It goes without saying that you must switch it off and leave it off if they ask you to. I never ask the cabin crew for permission and I am discrete with it when they walk past, so don't have any problems.
Make sure you record a tracklog of your trip, it's cool to play it back and see the flight path, approach, glide slope, take off speed etc. If your GPS supports it then make it display the vertical speed. Also, compare your GPS speed/height against that reported by the pilot during cruise. _________________ Gone fishing! |
Ice_coffee Occasional Visitor
Posted: Tue Nov 08, 2005 9:20 pm Post subject: |
I must admit, I flew to italy last month and managed to log (using TT5 & globalsat bt338) a take off of 190 mph and cruising speed of 520 mph , as an added bonus we didn't crash :-) |
Posted: Tue Nov 08, 2005 10:23 pm Post subject: |
Ice_coffee wrote: | cruising speed of 520 mph |
I think 630 MPH is the fastest I have seen. 8) _________________ Gone fishing! |
PompeyDave68 Occasional Visitor
Posted: Wed Nov 09, 2005 3:15 pm Post subject: |
Dilemma wrote: | Most flights have a display showing position, speed temperature and ETA. So do you really need your own? |
Besides which, i'd hope the Captain knew where he was going therefore you'd only need your set up to get you out of the airport!!! |
Posted: Wed Nov 09, 2005 4:53 pm Post subject: |
Of course you don't. Hey, you just sit back and enjoy the in-flight service. :D
It's only really long haul flights which do have in-flight information and even then it is switched off during the interesting part of the flight (takeoff, landing and flying over Afganistan).
Also, the maps aren't all that detailed compared to the streetmaps on a GPS or the basemap on Garmin GPS units. ie, it doesn't always show the name of major roads, towns and geographical features. _________________ Gone fishing! |
cartman Occasional Visitor
Posted: Sat Nov 12, 2005 10:22 pm Post subject: |
Not cheap, but WinPilot VFR here :
http://www.winpilot.com/VFR/generalvfr.asp
has good avaiation maps of large portions of the world.
Worked well en-route Glasgow -Orlando |
martike Regular Visitor
Posted: Sun Nov 13, 2005 3:24 pm Post subject: |
Skippy wrote: | You are not supposed to use it (or any other electronic equipment) during takeoff and landing, although I have done this many times |
That's very clever of you, Skippy. Congratulations.
Please post your future travel plans here so I can avoid your flights. |
Synth Regular Visitor
Joined: May 14, 2005 Posts: 78 Location: Perth, WA, Australia
Posted: Mon Nov 28, 2005 2:27 am Post subject: |
martike wrote: | Skippy wrote: | You are not supposed to use it (or any other electronic equipment) during takeoff and landing, although I have done this many times |
I do hope you are not on a flight to Oz next week.
I am surprised you haven’t been caught at this. It would almost certainly be a jail sentence for you. |
Posted: Mon Nov 28, 2005 8:32 pm Post subject: |
A good many airlines have no objection to people using a GPS reciever on their aircraft, under the normal rules for using devices like laptops, PDAs iPods etc. It goes without saying that you have to switch it off if the crew ask you to.
Going by the responses, I can only presume that Synth and martike are nervous or infrequent flyers. Relax, guys you won't get put in jail for using a GPS and you won't cause the plane to crash either.
I'll be in seat 1A if you are looking for me
Have a good trip! _________________ Gone fishing! |
Posted: Tue Nov 29, 2005 12:24 am Post subject: |
People have been jailed for using mobile phones on aircraft.
I do fly frequently and have survived an aircraft crash. Don't go telling me it will never happen. |
Posted: Wed Nov 30, 2005 1:48 pm Post subject: |
I’m not as frequent a flyer as I used to be, unfortunately, but that’s beside the point. I wanted to draw attention to Skippy’s attitude.
Skippy clearly knows the rules, deliberately breaks them, and then gloats about it afterwards. Grow up, Skippy, and act responsibly. |
etters Lifetime Member
Joined: Jan 18, 2005 Posts: 172 Location: Sunny Spain
Posted: Wed Nov 30, 2005 3:26 pm Post subject: |
Hi All
I'm just wondering what you would do if you found yourself flying the wrong way to where ever you were going _________________ Takara GP56 igo primo 1.1
Dont rely on them use your brain as well |
Posted: Wed Nov 30, 2005 4:07 pm Post subject: |
Synth wrote: | People have been jailed for using mobile phones on aircraft. |
I don't know this particular case, but I would guess that they weren't jailed for using the phone per se, but rather for refusing to switch it off when asked by the crew. I would guess that on any given flight, there would usually be at least one person who forgot to switch their phone off.
Synth wrote: | I do fly frequently and have survived an aircraft crash. Don't go telling me it will never happen. |
I'm not saying that a plane won't crash, just that using your GPS will not cause the plane to crash as you suggest.
As for mobile phones, they are trialing pico cells for use on planes while in flight. They wouldn't be doing this if there was any evidence that mobile phones could crash a plane.
Having said all that, I have now seen your point of view and I will never use my GPS on a plane again. I hope you can all fly in peace now. _________________ Gone fishing! |
