Pocket GPS World :: View topic - Jumping Roads
Jumping Roads
AndGPS
PostPosted: Mon Nov 07, 2005 12:52 am    Post subject: Jumping Roads Reply with quote
on my go 500 the little cursor thingy occasionally leaves the road and that means jane says some pretty stupid things anyway is this normal?
AndGPS
PostPosted: Mon Nov 07, 2005 8:07 am    Post subject: Reply with quote
Anyone? it kind of just leaves the road for a few seconds
This happens when the road, in real life, follows a different line to what is in the map data. TT will try to get you back on track until the road agrees to the map.
rkm_hm
PostPosted: Tue Nov 08, 2005 4:22 pm    Post subject: Reply with quote
Or when the GO loses sight of enough satellites to get an accurate fix. If this happens frequently - because, for example, you drive a lot in city centres with tall buildings, or have a heated windscreen, you may benefit from using an external antenna.
Roger
TomTom via135
Satmap Active 10+ v1.50 with full UK 1:50k map and 1:25k/1:10k County maps of Hampshire & Warwickshire
neil01
PostPosted: Tue Nov 08, 2005 4:53 pm    Post subject: Reply with quote
I think that is more to do with the software. Other people I know who use TomTom, report the same thing happenning to them. I think that TomTom is a little quick to change your position away from the route. Since GPS has an inherrent inaccuracy (regardless of the number of satelites fixes you have) - it can be fooled into thinking that you have moved away from your route.
Conversely, CoPilot (which I use) is perhaps a little bit the 'other way', in that it can take an age when you do deviate from the route, and sometimes even fail to recognise that you have moved to another parallel road.
So it is probably a case of TomTom being better when you do move away from your route, and CoPilot being better when you don't. Unfortunately, each way of working has a downside too.
rkm_hm
PostPosted: Tue Nov 08, 2005 5:13 pm    Post subject: Reply with quote
I find quite the reverse. It will always try to snap to the nearest road. There is one place where I go, where there is a new by-pass not yet on TTG's map. When I drive along it, TTG hangs on to the old road for a couple of hundred yards before suddenly jumping into the middle of a field!
Roger
TomTom via135
neil01
PostPosted: Wed Nov 09, 2005 7:24 pm    Post subject: Reply with quote
It may well be that it is a little more reluctant to jump when there is no road for it to jump to. The situations I have observed were all where there was a road to jump to.
22.063 (19 Jun 24)
