Pocket GPS World :: View topic - hi-203e
hi-203e
alanj
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: hi-203e Reply with quote
i have bought a haicom hi-203e with infomap navigator, when i try to run it i am getting a message back saying no data received. i am running xp on my laptop and i have instaled xp drives from haicom i would appreciate any help in solving this problem.
cheers
alan
ps i have also tried visualgps with no success
DavidW
So far as I can tell, you shouldn't need any drivers - the HI-203E is a serial port GPS. It should be a case of selecting NMEA at 4800bps on whichever COM port you've plugged the GPS in to.
What you must do, assuming you have the 9 pin serial lead, is connect the PS-2 plug to a PS-2 port on your laptop. The GPS uses that connection for power.
Falken
Are you using the USB model? Go into control panel, hardware, ports and see which post prolific serial-usb is allocated to. Then go into Navigator. Tools, settings, GPS and set the port to the correct value. Make sure the baud rate is set to 4800.
22.063 (19 Jun 24)
