Pocket GPS World :: View topic - Anyone else lose POI-W after speed camera update ??
jblackmore
PostPosted: Mon Oct 31, 2005 6:01 pm    Post subject: Anyone else lose POI-W after speed camera update ?? Reply with quote
I am using Mapsonic 2.52 and realised some time ago that when updating POI's (ie speed camera's), its important to check the POI display and warn settings are not mucked up.
I just did the October updates, and found POI-D not changed, but POI-W was switched off for GATSO/TEMP but MOBCAMS was not affected ??
Anyone else noticed this, as it seems a bit bizarre, ideally updating POIs shouldn't affect the POI-D or POI-W settings at all, but for it to randomly affect them seems a bit weird, even for French software ??
Anyway, just a mention to check the POI-D/W tickboxes after updates so you don't get caught out !
elan2s
PostPosted: Wed Nov 02, 2005 11:16 am    Post subject: Reply with quote
In the past I have had the same problem (on both v2.5 and v3.x) but this month the problem didn't occur. The only difference this month was I used the pocketgps .asc files directly into POI Manager rather than going via POI Edit
jblackmore
PostPosted: Thu Nov 03, 2005 3:01 pm    Post subject: Reply with quote
I have been using the asc files for a couple of months, so maybe it is something random ??
Oh well, not a problem if you know to check after updating !!
BaggieBoy
PostPosted: Sun Nov 06, 2005 5:01 pm    Post subject: Reply with quote
I'd never had this problem before the October update, this was the first time I'd used the .asc files directly.
22.064 (26 Jun 24)
