Vic_Tina Occasional Visitor
Posted: Thu Nov 03, 2005 9:20 pm Post subject: TTN 5 help please |
Installed TTN5 a couple of days ago and initially was having the problem of favourites and POI settings vanishing but thanks to the fantastic help on this forum I have managed to sort that (map was ticked for read only).
Feeling very brave I decided to attempt installing a new camera database using POI Edit but it wouldn't download all the camera files, then tried to do it manually which seemed to work but I can't get them to show properly. All I get is the different camera icons but not what the speed restriction is which I really want to be able to see.
Should I delete all the camera database and start again, if so which database do I download to see the speed limits or is there a way to get it sorted.
Hope the question makes sense or if you need more info to help then please ask.
Thanks _________________ Not that technical
Mio 168
TomTom 5.10
1GB Kingston SD card |
Oldboy Pocket GPS Moderator
Posted: Thu Nov 03, 2005 10:25 pm Post subject: Re: TTN 5 help please |
Vic_Tina wrote: | Should I delete all the camera database and start again, if so which database do I download to see the speed limits or is there a way to get it sorted. |
The database on this site is the best there is. (I'm biased.)
For a summary of the different files that are available for TT, have a look at this.
TTN5 uses the same setup as the GO with regard to the camera files.
Remember there is a limit to how many POI categories you can add to TT. _________________ Richard
Posted: Fri Nov 04, 2005 12:02 am Post subject: |
So if I delete the mish mash of files I have now and just add the speed zoned files back thats all I have to do?
thanks for the help by the way. _________________ Not that technical
Mio 168
TomTom 5.10
Posted: Fri Nov 04, 2005 12:08 am Post subject: |
Sorry to be a pain but I seem to have misplaced the files, could you post a link for the download for ....
"These are found in the 'speed zoned/gatso/ov2 bmp', 'speed zoned/mobile/ov2 bmp' and 'speed zoned/Specs/ov2 bmp' folders. Add to these the Redlight and Temporary files as above."
Thanks again. _________________ Not that technical
Mio 168
TomTom 5.10
LiveLifeGoJump Regular Visitor
Posted: Fri Nov 04, 2005 12:36 am Post subject: |
You will find the camera database at http://www.pocketgpsworld.com/uksafetycameras.php (which is the page the 'speed camera' link on this site takes you. Click on download database, unzip it & select the files you need to copy to the SD card.
Norman _________________ If riding in a plane is flying then riding in a boat is swimming. If you want to experience the feeling
GET OUT OF THE VEHICLE |
Posted: Fri Nov 04, 2005 7:21 pm Post subject: |
Thanks again for your help. _________________ Not that technical
Mio 168
TomTom 5.10
