Pocket GPS World :: View topic - No com port 5 on TTN5
teecee90
PostPosted: Thu Nov 03, 2005 2:06 am    Post subject: No com port 5 on TTN5 Reply with quote
Is there any way to change the GPS com ports available within TTN5? the only com port I can attach my GPS (Holus GPSlim 236) to on the Orange SPV m1000 is com 5 but TTN5 only gives me the BT on Com 6 option in the GPS configuration screen.
PostPosted: Thu Nov 03, 2005 3:35 am    Post subject: Reply with quote
TTN5 is not messing with ports any more (TTN3 was). Most probably you have another program running that occupies the COM port. Do a soft reset and try again.
Ianh
PostPosted: Thu Nov 03, 2005 1:19 pm    Post subject: Reply with quote
teecee90
Make sure you have your IR Beam turned off on your M1000 - You'll find this under Start--> Settings --> Connections --> Beam - Simply make sure the box to recevive all incoming beams is unchecked. - This is known to cause problems with all com ports on M1000's - Hope this helps.
Ian
teecee90
PostPosted: Fri Nov 04, 2005 9:43 am    Post subject: Reply with quote
Thanks for the suggestions. I managed to sort it out by using a bluetooth utility I found via the XDA developers forum. I got it here:
http://bluetooth.i-networx.de/index_e.html
It enabled me to specify a particular SPP port after bonding the GPS. I chose port 4 and then when I went into TTN5 and selected GPS configuration the Holux just appeared in the "other bluetooth receiver" section as if by magic.
Sweet!
Rather than it being a com port problem I wonder whether the SPV M1000 doesn't uses SPP by default when bonding bluetooth devices ?? Or maybe Im just showing my ignorance of these things.
