RWB Occasional Visitor
Posted: Tue Nov 01, 2005 6:47 pm Post subject: Tom Tom go 300 no speed cameras in 50 miles.[I WISH] |
Can anyone help please? Downloaded speed cameras into TTG fine but not showing any speed cameras within 56.8 miles of home then shows loads upto 210 miles away. Red light cameras all showing up o.k.
ps loads of speed cameras within 5 miles of home. Thanks. |
Joined: 30/12/2002 17:36:20 Posts: 4914 Location: Oxfordshire, England, UK
Posted: Tue Nov 01, 2005 7:09 pm Post subject: |
Hi RWB,
to the forum!
Which TomTom GO are you using (GO, 300, 500, 700)?
Which version of the application are you using?
Application 5.2xx only allows the use of 27 user POIs.
There are some guides that should be read (in the following order):
The beginner’s guide to the PocketGPSWorld camera database.
This explains about the different camera types and about categories and subcategories, so that you can decide how you want the database on your unit.
Depending on whether you have TomTom Navigator on a Pocket PC or TomTom GO, please read either:
How to install (camera database) POIs to TomTom Navigator 5.
This guide explains how to load the PocketGPSWorld camera database onto a Pocket PC running TomTom Navigator 5.
How to install (camera database) POIs onto a TomTom GO.
This guide explains how to load the PocketGPSWorld camera database onto your TomTom GO.
The above guides may look lengthy and complicated when first seen. However if you grab a cup of coffee and read each one thoroughly then they should make sense as they have been written in a step-by-step way, for ease of reading.
Garmin Camper 770 LMT-D |
Posted: Tue Nov 01, 2005 10:34 pm Post subject: no speed cameras in 50 miles |
using tomtom go 300 App 5.000
showing 30mg ram[free3.1mb] |
sgould Frequent Visitor
Posted: Wed Nov 02, 2005 1:55 am Post subject: |
Free RAm and free MB are irrelevant. The GO with version 5.2 or later software will only see 27 PoI categories, whether enabled or not. If you have exceeded this limit some of the speed categories will not show. _________________ TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps |
ApriliaFalco Occasional Visitor
Posted: Fri Nov 04, 2005 6:53 pm Post subject: GO 300 Spped Camera |
Hi, Im new to this as well,have tried copying and then pasting ov2 and bmp files to the sd card and tried following the instructions on the guide on this web site , but still can't get the new icons to show let alone identify cameras What have i done wrong ? |
Oldboy Pocket GPS Moderator
Posted: Fri Nov 04, 2005 8:10 pm Post subject: Re: GO 300 Spped Camera |
ApriliaFalco wrote: | Hi, Im new to this as well,have tried copying and then pasting ov2 and bmp files to the sd card and tried following the instructions on the guide on this web site , but still can't get the new icons to show let alone identify cameras What have i done wrong ? |
The list of files you need are shown here - http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&p=151199
Did you copy the files, or the Folders with the files? Only files must be copied. TT can only see the files in the Map Folder.
How many added POI categories do you have? There is a limit of 27. _________________ Richard
Posted: Fri Nov 04, 2005 8:25 pm Post subject: |
In the folder Great_Britain-map\ov2bmpfiles there are 27 bmp files and 27 ov2 files |
Posted: Fri Nov 04, 2005 8:35 pm Post subject: |
Check this:
Touch screen bottom right.
On next screen touch "Route" - bottom left.
Next screen touch "Browse map of route".
Next screen touch "Options" bottom left.
Next screen make sure "Points of Interest" box is ticked. _________________ TTGO 700 (dead)
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Posted: Fri Nov 04, 2005 8:38 pm Post subject: |
You have got the PoIs enabled in Prefs/Manage PoI/Enable Disable POI? _________________ TTGO 700 (dead)
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Andy_P Pocket GPS Moderator
Posted: Mon Nov 07, 2005 4:24 pm Post subject: |
ApriliaFalco wrote: | In the folder Great_Britain-map\ov2bmpfiles there are 27 bmp files and 27 ov2 files |
There's your problem!
The ov2 and bmp files must go INDIVIDUALLY in the Great_Britain-map folder, not inside any other sub-folder.
Try moving them out of your "ov2bmpfiles" folder and all should be well. |
Posted: Tue Nov 22, 2005 7:27 pm Post subject: no speed cameras in 50 miles |
SORTED OUT NOW !!
I had only copied two of the files and not four as required
had downloaded uk redlight/uk specs but not continental/uk gatso.
Since downloading these all cameras now showing up.
Thanks for the advice everyone
Ron. :D |
