Pocket GPS World :: View topic - i3 Firmware 2.70
i3 Firmware 2.70
Goto page 1, 2, 3  Next
antwalsh
PostPosted: Tue Nov 01, 2005 11:36 am    Post subject: i3 Firmware 2.70 Reply with quote
2.70 firmware is out, changes are:
Changes from 2.60 to 2.70
1) Add City selection step for address and intersection searches.
2) Corrected error in extended postal code searches that would cause
the same result to be returned for different searches and prevented the result from being added to the recent finds list.
3) Detect driving away from route more quickly.
4) Disable the detour option on the main menu when satellites are lost.
5) Updated text translations for Swedish, Polish, Dutch, Portuguese,
Spanish, Czech, and German.
6) Fixed a problem where a user's scroll position was lost after long searches.
7) Prevent language changes when user inserts a data card for a different region.
gcb
PostPosted: Tue Nov 01, 2005 4:50 pm    Post subject: Reply with quote
Surely they must have it ablout right this time or should we expect updates every fortnight.
Uploadede 2.7. Didnt use the web updater, anyone tried that, dont quite see how it helps.
awalsh
PostPosted: Tue Nov 01, 2005 7:10 pm    Post subject: Reply with quote
Given my experiences, I cant see them getting it right until at least v4.x!
I did use the Webupdater, saves having to go to the website and manually download, then install I guess.
Garmin i3 | Orange SPV M500 with TomTom 5.10
sfcman
PostPosted: Tue Nov 01, 2005 9:07 pm    Post subject: Reply with quote
I know it's perhaps a bit early to be asking, but any comments regarding 2.70's stability would be welcome, particularly in view of the remarks made about 2.60.
jog_on
PostPosted: Tue Nov 01, 2005 9:13 pm    Post subject: Reply with quote
Just used the webupdater to update I3 from 2.6 to 2.7 and my I3 turned itself off halfway through update. Cannot get unit to power up at all now, tried new batteries/USB and car adapter and no joy. Sad GUTTED
Think i'm gonna have to return this unit tommorow. Has anyone else had a similar problem?
Jaz666
PostPosted: Tue Nov 01, 2005 9:28 pm    Post subject: Reply with quote
If you are a laptop user be very careful when updating firmware.
Some Laptops (and desktop machines which use USB hubs) don't supply enough voltage through the USB port to fully power devices like the i3.
I've seen one flick between computer and battery power several times whilst connected. I'd advise always using fresh batteries when updating firmware.
On a related note, I uploaded the 2.70 update onto a i3 unit today and the unit shut itself off a couple of times during the day (first time I've seen it do that).
jog_on
PostPosted: Tue Nov 01, 2005 9:40 pm    Post subject: Reply with quote
I've had it plugged into my desktop quite a few times, uploading POIs and software upgrades, and never had any problems before. I still can't get it to power on. Might see if I can get a refund as I paid 199.99 for it and see if I can find one for 169.99 in another store. Never know I might get lucky and purchase one with V8 maps that everyones going on about. They're buggars for refunds at PC World though. Oh well - fingers crossed...........
mcintyre
PostPosted: Tue Nov 01, 2005 11:52 pm    Post subject: Reply with quote
Think I'll be sticking with 2.50 for the time being then.....
ps73uk
PostPosted: Wed Nov 02, 2005 10:24 am    Post subject: Reply with quote
yes 2.7 does seem to be as buggy as 2.6 was, used it for most of the day yesterday and it crashed 3 times something it never ever does on 2.5, it also like i said before when i was running 2.6 seems to slow the unit down, i have also noticed when going past a POI the map seems to hesitate and pause for a few seconds then carries on, again something it never does in 2.5
Also noticed with 2.7 as with 2.6 that it seems to have affected the unit when i'm switching it off, seems to make all sorts of strange noises instead of the normal switching off sound!
My opinion, if you need the 2.7 upgrade for the postcodes to work properly then it's probably worth the upgrade, if you dont, you would probably be better off staying with 2.5
Garmin Streetpilot i3,
Tomtom One
Paul
mick7020
PostPosted: Mon Nov 07, 2005 10:47 pm    Post subject: 2.70 formware upgrade Reply with quote
Hi guys...
i have tried this a few times now and have finally got it to upgrade without a problem.
The fault i could reproduce only when my i3 was connected to my usb hub..
When tried with a powered usb hub it worked fine.
When tried connected direct to my computer it worked fine...
it seems the problem is if you have a low powered usb hub...
mick
Leep
PostPosted: Sun Nov 13, 2005 5:48 am    Post subject: i3 update fail Reply with quote
I tried updating my i3 yesterday to 2.7 and it failed. Can't turn on my unit now even after resetting. I'm waiting for Garmin to respond to my email on this. Anyone have some advice on a fix?
avantone
PostPosted: Sun Nov 13, 2005 9:27 am    Post subject: Reply with quote
Had mine about 4 days now and used it a fair bit. It came loaded with 2.50 and v7 out of the box (Halfords online £169). I loaded the POI's and 2.70 immediately and the unit has been faultless since (with the exception of some questionable routing).
NoLCD
PostPosted: Sun Nov 13, 2005 7:37 pm    Post subject: Earlier Firmware Reply with quote
Now that Garmin are only distributing 2.7 is there anyway of retrieving earlier
(more stable?!) versions i.e. 2.5?
Great info on these forums! Keep it up.
dougconran
PostPosted: Mon Nov 14, 2005 1:06 am    Post subject: Reply with quote
This post has some links to v2.5 (or, at least, they were there when the thread was started).
NoLCD
PostPosted: Mon Nov 14, 2005 11:32 am    Post subject: V2.5 download site Reply with quote
Thanks! The link is still good.
Page 1 of 3
