Pocket GPS World :: View topic - REVIEW COMMENTS: GlobalSat BC-307 CF
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: REVIEW COMMENTS: GlobalSat BC-307 CF Reply with quote
Darren has completed his review of the GlobalSat BC-307 Compact Flash GPS Receiver. Not only that, but it's our first review with a Tablet PC!<br>
<br>
Take a look at the full review here
Maxime
I have a BC-307 and I am some perfectly happy. It has the new firmware SIRF 2.31 that gives the value of the geoid above the ellipsoid WGS84, to see the example of the $GPGGA sentence:
$GPGGA,095101.674,4230.4785,N,00321.7083,E,1,07,1.1,167.4,M,49.9,M,0.0,0000*7A
in this example the value of the geoid is 49.9M.
It is compatible DGPS SBAS WAAS/EGNOS.
Maxime
DavidW
Maxime - as a matter of interest, do you know the precise SiRF firmware version?
My 2.31 Haicom HI-303MMF is version 231.000.000ES - which I suspect may be an "Engineering Sample" firmware. It works perfectly OK - am just wondering if SiRF have moved on beyond that, or whether that's a firmware that many vendors are now shipping.
Maxime
It is the same FW that I have on my BC307, I use SIRFDemo 3.40 to make tests on PC.
To my knowledge it makes the second GPS that has this FW.
Maxime
Frodo
PostPosted: Thu Sep 25, 2003 10:13 pm    Post subject: Reply with quote
I am pretty new to GPS and I saw this discussion about the BC-307.
I just purchased this unit and I am waiting for my Deluo Routis 2004 software.
You guys have been talking about firmware.
How do I find out what firmware I have ?
Do I need the latest firmware?
Also, I was wondering about WAAS and DGPS.
Does it depend on the software to utilize DGPS for example? I read that DGPS is more accurate but with Delorme StreetAtlas and MS Streets & Trips I never knew if DGPS was in use or not?
I need to learn a lot Smile ......
PostPosted: Thu Sep 25, 2003 10:20 pm    Post subject: Reply with quote
WAAS/SBAS/DGPS is when available more acurate than the standard fix. Under most circumstances you will not realise that it is in use. Other than setting the correct option there is nothing else to do and corrected fixes will be used automatically irrespective of what software you are using.
In fact the only mapping application I know of that shows the DGPS status is OziExplorer CE.
aguy2no
PostPosted: Wed Sep 08, 2004 1:01 pm    Post subject: I've been using this gps on a ipaq-2210 (2215) Reply with quote
:D Its been easy to use, and generally works great. Occassionally it loses its signal but will regain it in 10-30 seconds.
In car, or close to a window i have not had to use, nor did i purchase the external antenna and found favorable results anyway.
With mapopolis it speaks through my pda, and recalculates quickly.
It was the cf model with a pcmcia adapter.
My opinion, you can't go wrong.
Aguy2no
ps found it on ebay about a year ago for about $100
Magicands
PostPosted: Tue Oct 05, 2004 1:03 am    Post subject: Reply with quote
is there a typo in the review, which states that a solid light indicates position fixed and a blinking light indicates the unit is searching for a fix?
My unit works in reverse to this......Solid light means NO FIX and blinking means FIXED.
hammy96
PostPosted: Wed Nov 17, 2004 8:27 pm    Post subject: Reply with quote
Hi Magicands,
Yes your right I have a BC 307 and it does state in the manual that LED on it is searching, LED flashing position fixed.
hammy96
murf62
PostPosted: Fri Jan 13, 2006 1:07 pm    Post subject: Reply with quote
Has anyone managed to get this working on Windows Mobile 5 with TTN5 ver 5.21? I just can't get it to connect. My BT receiver works fine with it though. Sad
Maverickuk
PostPosted: Fri Jan 13, 2006 11:19 pm    Post subject: Reply with quote
See here
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=33339
Only a semi workaround tho
Regards
Mav
23.034 (26 Mar 25)
