Pocket GPS World :: View topic - Tom Tom go 300 no speed cameras in 50 miles.[I WISH]
RWB
PostPosted: Tue Nov 01, 2005 6:47 pm    Post subject: Tom Tom go 300 no speed cameras in 50 miles.[I WISH] Reply with quote
Can anyone help please? Downloaded speed cameras into TTG fine but not showing any speed cameras within 56.8 miles of home then shows loads upto 210 miles away. Red light cameras all showing up o.k.
ps loads of speed cameras within 5 miles of home. Thanks.
Privateer
PostPosted: Tue Nov 01, 2005 7:09 pm    Post subject: Reply with quote
Hi RWB,
Welcome to the forum! Thumbs Up
Which TomTom GO are you using (GO, 300, 500, 700)?
Which version of the application are you using?
Application 5.2xx only allows the use of 27 user POIs.
There are some guides that should be read (in the following order):
Arrow The beginner’s guide to the PocketGPSWorld camera database.
This explains about the different camera types and about categories and subcategories, so that you can decide how you want the database on your unit.
Depending on whether you have TomTom Navigator on a Pocket PC or TomTom GO, please read either:
Arrow How to install (camera database) POIs to TomTom Navigator 5.
This guide explains how to load the PocketGPSWorld camera database onto a Pocket PC running TomTom Navigator 5.
Arrow How to install (camera database) POIs onto a TomTom GO.
This guide explains how to load the PocketGPSWorld camera database onto your TomTom GO.
The above guides may look lengthy and complicated when first seen. However if you grab a cup of coffee and read each one thoroughly then they should make sense as they have been written in a step-by-step way, for ease of reading.
Robert.
Garmin Camper 770 LMT-D
RWB
PostPosted: Tue Nov 01, 2005 10:34 pm    Post subject: no speed cameras in 50 miles Reply with quote
using tomtom go 300 App 5.000
showing 30mg ram[free3.1mb]
sgould
PostPosted: Wed Nov 02, 2005 1:55 am    Post subject: Reply with quote
Free RAm and free MB are irrelevant. The GO with version 5.2 or later software will only see 27 PoI categories, whether enabled or not. If you have exceeded this limit some of the speed categories will not show.
TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
ApriliaFalco
PostPosted: Fri Nov 04, 2005 6:53 pm    Post subject: GO 300 Spped Camera Reply with quote
Hi, Im new to this as well,have tried copying and then pasting ov2 and bmp files to the sd card and tried following the instructions on the guide on this web site , but still can't get the new icons to show let alone identify cameras What have i done wrong ? Question Crying or Very sad
PostPosted: Fri Nov 04, 2005 8:10 pm    Post subject: Re: GO 300 Spped Camera Reply with quote
The list of files you need are shown here - http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&p=151199
Did you copy the files, or the Folders with the files? Only files must be copied. TT can only see the files in the Map Folder.
How many added POI categories do you have? There is a limit of 27.
ApriliaFalco
PostPosted: Fri Nov 04, 2005 8:25 pm    Post subject: Reply with quote
In the folder Great_Britain-map\ov2bmpfiles there are 27 bmp files and 27 ov2 files Confused
sgould
PostPosted: Fri Nov 04, 2005 8:35 pm    Post subject: Reply with quote
Check this:
Touch screen bottom right.
On next screen touch "Route" - bottom left.
Next screen touch "Browse map of route".
Next screen touch "Options" bottom left.
Next screen make sure "Points of Interest" box is ticked.
TTGO 700 (dead)
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
sgould
PostPosted: Fri Nov 04, 2005 8:38 pm    Post subject: Reply with quote
You have got the PoIs enabled in Prefs/Manage PoI/Enable Disable POI?
TTGO 700 (dead)
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
PostPosted: Mon Nov 07, 2005 4:24 pm    Post subject: Reply with quote
There's your problem!
The ov2 and bmp files must go INDIVIDUALLY in the Great_Britain-map folder, not inside any other sub-folder.
Try moving them out of your "ov2bmpfiles" folder and all should be well.
RWB
PostPosted: Tue Nov 22, 2005 7:27 pm    Post subject: no speed cameras in 50 miles Reply with quote
SORTED OUT NOW !!
I had only copied two of the files and not four as required
had downloaded uk redlight/uk specs but not continental/uk gatso.
Since downloading these all cameras now showing up.
Thanks for the advice everyone
Ron. :D Smile
22.064 (26 Jun 24)
