SpeedCam Frequent Visitor
Joined: Mar 18, 2004 Posts: 753 Location: Biggleswade, BEDS
Posted: Mon Oct 31, 2005 9:20 pm Post subject: TT V5 & o2 XDA Exec - Stability |
Is anyone else experiencing stability problems running TT V5 on the new XDA Exec. I know WM2005 is not officially supported yet, but I've not been able to complete a journey without the Exec crashing/locking....
I'm not sure if its WM2005 thats causing the problem as I've not had any problems with the XDA IIi, or TomTom.
Other things that maybe the causing the problems, I've upgraded the firmware using the I-Mate ROM, and used the resource editor and modified the Navigator.exe to correct the VGA issues.
Other things I've noticed since using TT on the Exec, system notifications ie new emails, battery low and connecting to traffic, freeze TT whilst they complete, which indicates that its not multi tasking correctly. |
alix776 Pocket GPS Moderator
Posted: Mon Oct 31, 2005 10:22 pm Post subject: |
does the freezing only happen with tt5 runing I'm using the standard o2 rom and it does freeze while download traffic and emails I think its more to do with tt5 though but it seams fine if tt5 is not running also if you use o2 active it doesn't seam have the same disasterous effect as on wm2003se it just seams to slow the device down alittle so I'm using the basic setup now as active started to cheese me off _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Mon Oct 31, 2005 11:21 pm Post subject: |
Thats helpful, I experienced a number of lockups when I was running the original o2 Exec ROM, I've since upgraded to the iMate and now the Exec is a lot more stable. The crashes are only when running TT, they are at random times and can be within the first 5 minutes or after 1.5hours totally random. If the Exec is reset prior to use it seems to run longer. |
