Pocket GPS World :: View topic - Changing Alert speed on Streetpilot i3?
mitzyjim
PostPosted: Thu Oct 27, 2005 10:06 pm    Post subject: Changing Alert speed on Streetpilot i3? Reply with quote
After seeking advice on this forum I took the plunge and bought an i3 a few days ago, what a great piece of kit!
I have found answers to most of my questions on here already but need help on one more. I can't seem to change the alert speed/distance on the speed cameras settings in POI loader. I have used manual mode and tweaked both speed and distance, but when I look at the settings on the i3 itself they have gone back to the defaults?
Any ideas?
thanks :D
mitzyjim
PostPosted: Fri Oct 28, 2005 3:19 pm    Post subject: Reply with quote
Hi Guys
as no-one has replied, does that mean that I am the only one with this problem? Unless I have read it wrong, I thought that the idea of manual mode on POI loader meant that you could change the speed and/or distance for POI's with proximity alerts?
Please advise, as if I have a faulty unit I need to take it back!
:D
pauljmuk
PostPosted: Fri Oct 28, 2005 6:27 pm    Post subject: Reply with quote
There are some other threads on this subject on here. Basically, you can alter the alert in the csv file you are loading up. 3rd or 4th column I think
Pauljmuk ::::
DSL - Don't Say Leonard
gottai3
PostPosted: Sat Oct 29, 2005 5:18 pm    Post subject: Reply with quote
the 3rd or 4th column in the csv says something like @30 I guess indicating that its a 30 mph zone camera.
But my i3 says 19mph speed limit near these cameras and 'bongs' at me. I think that when i'm travelling at over 19mph in 30 mph camera areas it gives this warning. But I dunno how you change this setting
JeffG
PostPosted: Sat Oct 29, 2005 6:52 pm    Post subject: Reply with quote
19 mph = 30 km/h. Check your units settings.
rother
PostPosted: Sun Oct 30, 2005 1:42 pm    Post subject: help Reply with quote
Still confused, should the i3 give a warning visual or sound for a gatso even if i am going under the speed limit.
i have tried it driving past gatso's that are on the dbase and not had a bleep out of it.
mobile ones it bleeps and i get a message whether i am under or over the limits.
how do i set the unit to show redlight camera been through loads and no indication, at green i meen.
many thanks
rother
JeffG
PostPosted: Sun Oct 30, 2005 2:22 pm    Post subject: Reply with quote
Mine gives me a bong on approach then nothing more if below speed limit, otherwise continuous warnings until past the camera. (There are loads on the M4 in Wiltshire - very annoying!).
Why do you need red light camera warnings? I can understand people exceeding the speed limit (but of course my legal advice says I can't condone that Wink ), but there is absolutely no excuse for going through a red light!
Jeff.
pauljmuk
PostPosted: Sun Oct 30, 2005 2:25 pm    Post subject: Reply with quote
Somebody I know went through a light on green - car in front stalled and he was stuck on the junction.
Red light cam got the impression he had jumped the light - and he got a penalty.
Appealed of course and got off - glitch in the cam
Pauljmuk ::::
rother
PostPosted: Sun Oct 30, 2005 3:00 pm    Post subject: Reply with quote
jeffg thanks how did you set them files up through the uploader, when i change mine through manual to use a distance, it accepts what i want but then when i use the loader again it has gone back to how it was before.
i agrre with the redlight but i prefer to see what is coming up all the time so i can adjust my speed, my other gps does this and in this respect i think it is better.
A similar thing happened last week as i approached the redlisgts were green as i hit it it turned amber but a lorry infront was turning right and then stopped so i was halfway over at red so i might have been caught.
JeffG
PostPosted: Sun Oct 30, 2005 6:04 pm    Post subject: Reply with quote
There are others here who know more about this. I just uploaded safety camera POI files on auto (idiot mode).
Jeff.
MELennium
PostPosted: Sun Oct 30, 2005 6:26 pm    Post subject: Reply with quote
If i'm reading you correctly,then each time you use the POI loader it defaults back. This is normal & you have to change individual speeds & distance to suite your requirements every time you load updated poi's in manual mode.
rother
PostPosted: Sun Oct 30, 2005 6:47 pm    Post subject: Reply with quote
MELennium
thanks that makes sense now, it is confusing.
i had better luck today as it showed up some gatsos, no complaints with the routing though which is the main thing.
many thanks
gottai3
PostPosted: Sun Oct 30, 2005 9:15 pm    Post subject: Reply with quote
If it's not showing up red light cameras, it's prob because you didn't tell it where they are. The speed camera database is made up of several different files and you have to load them all to your unit, or use the single file option which is one big file with all of them in. I discovered this after reading the help files in the first thread of this forum.
I don't think that red light cameras are all only checking light jumping. Last week I was driving along a dual carrigeway in a 30mph zone. I was on the inside doing 30 and a car shot past me in the outside lane doing 40plus? The lights were on green to us, but the camera flashed him twice!
23.012 (08 Jan 25)
