zogman Frequent Visitor
![](modules/Forums/images/avatars/4129001634330026455503.gif)
Joined: Sep 05, 2005 Posts: 1417 Location: swindon uk
Posted: Thu Nov 03, 2005 10:17 am Post subject: |
you can use the city select from your 60c and you will have voice naviagation...cant see the benifit of doing this unless you plan to use the i3 in europe...DONT overite the existing mapping on the transflash card , use a blank card... _________________ *************************** |
telecaster Occasional Visitor
Posted: Thu Nov 03, 2005 11:04 am Post subject: Re: Garmin Streetpilot i3 |
erniesone1 wrote: | I have been using the Garmin 60C for a couple of years. It has lots of ‘bells and whistles’ but for in-car use the i3 is excellent, in particular the wheel zoom.
One aspect I miss on the i3 is lack of Car Park data on maps. Does anyone know if all the extra data ( POI’s) on City Select would be available if this mapping is loaded onto a separate Transflash and used in place of the existing card?
I assume I would however lose the voice commands by using City Select software from my 60C.
My set-up will be of no interest to anyone – but I will give it anyway. I have one of those funny windscreens and had my aerial on the dash right next to the drivers door. Signal usually OK but after reading earlier reports (that glass is not treated behind drivers mirror) I placed aerial on the back of the mirror (with Velcro). Aerial wire is very easy to hide around edge of the windscreen. Better signal but aerial can fall off. So I built a little platform on the mirror base (with fibreglass) so the aerial sits right next to the glass and I get 5 columns nearly all the time.
I had my 60C holder bolted onto a central, dash, air-vent (Peugeot 406). Removing the vent cover the i3 just about sits in. A hole drilled in rear side of the plastic vent housing (watch what is behind) allows aerial and power leads to fit from under the dash. I placed cling-film in the gap (in case I wish to remove later), shot in some foam filler; wrapped the i3 and leads in cling-film and placed in space. Allow to dry, cut off excess filler, top off with plastic padding; sandpaper and paint. i3 is now totally secure for pressing buttons, is not obvious from the street, can be removed and replaced easily. |
Hey that sounds cool......any photos available? |
survivalskills Occasional Visitor
Posted: Thu Nov 03, 2005 1:02 pm Post subject: i3 Transflash backup problem |
I've just got an i3 after trying one at the weekend, and the first thing I wanted to do was to back up the installed Transflash card... however, having put the card in a reader, I'm not able to see any files on it. The size of the drive is initially mis-reported and then when I click on it, says it doesn't exist...
Any ideas if this is a card reader problem, or some kind of copy protection? |
Posted: Thu Nov 03, 2005 1:41 pm Post subject: Re: i3 Transflash backup problem |
survivalskills wrote: | I've just got an i3 after trying one at the weekend, and the first thing I wanted to do was to back up the installed Transflash card... however, having put the card in a reader, I'm not able to see any files on it. The size of the drive is initially mis-reported and then when I click on it, says it doesn't exist...
copy protection.....imagine the problems garmin would have if you could copy and illegally distribute the maps... _________________ *************************** |
Posted: Thu Nov 03, 2005 1:52 pm Post subject: Re: i3 Transflash backup problem |
zogman wrote: |
copy protection.....imagine the problems garmin would have if you could copy and illegally distribute the maps... |
Drat... let's hope the card has a decent lifespan then...
Forgive the newbie questions, but I'm ploughing steadily thru the i3-related topics on here 8O |
Tubal Occasional Visitor
Posted: Thu Nov 03, 2005 3:56 pm Post subject: |
I use my transflash card in a sd "cover" and can copy the contents to my PC no problem. |
Posted: Thu Nov 03, 2005 4:10 pm Post subject: |
Tubal wrote: | I use my transflash card in a sd "cover" and can copy the contents to my PC no problem. |
have you tried loading the copied maps to a blank card and then inserting the card into your i3....i remember someone on the forum tried this and it didnt work.... _________________ *************************** |
erniesone1 Occasional Visitor
Posted: Thu Nov 03, 2005 8:19 pm Post subject: |
You should be able to 'read' the files from the i3 card. I copied them to my PC and back to a separate Transflash. Copied OK but i3 just asks for the correct software.
I need another City Select licence in order to make it work - but I wish to know if there is an advantage i.e get all the City Select POI's) before I spend the cash.
I will take some photos of my setup (see above) and publish where the are. |
Posted: Fri Nov 04, 2005 1:30 pm Post subject: |
thats a nice setup mate..can you still hear the voice commands clearly. _________________ *************************** |
Posted: Fri Nov 04, 2005 2:51 pm Post subject: |
zogman wrote: | thats a nice setup mate..can you still hear the voice commands clearly. |
Yes sound on level 4 is fine even with the radio on. I have made a few comments with photos - they appear lower right if you use the 'view a slideshow' - not a great photo facility but Hey, it's free. |
MELennium Frequent Visitor
![](modules/Forums/images/avatars/44197630643a4646455512.gif)
Joined: Sep 25, 2005 Posts: 337 Location: County Durham
Posted: Fri Nov 04, 2005 9:27 pm Post subject: |
Great idea erniesone1, but does the indicator & or the steering wheel not block your view of the i3? |
Bolty Occasional Visitor
Posted: Sat Nov 05, 2005 9:11 am Post subject: |
Does anyone still get the white square/black dot instead of the speed limit icon?
I've checked my colour depths etc and they're OK.
Any help would be appreciated.
Confused! |
kevinbev Occasional Visitor
Posted: Sat Nov 05, 2005 10:20 am Post subject: |
I believe it is because that the bmp file should be titled the same as the csv file and that the dots and dashes must be the same as well. So if the bmp file comes up as pocketgps_uk_mobile_30 then the csv file must be exactly the same. Also make sure the correct icon is allocated for the relevant item. |
Posted: Sun Nov 06, 2005 1:54 pm Post subject: |
The files all have exactly the same name (apart from the extension).
Thing is, I'm sure it worked once!
I've tried changed the colour depth too. No change!
Weird! |
