Trigger Regular Visitor
Joined: Feb 01, 2005 Posts: 74 Location: Wolverhampton
Posted: Mon Oct 24, 2005 9:15 pm Post subject: Help Needed |
I have just switch from power GPS to Bluetooth Iwonder if any one can help me with the following:
I have an XDA2s with BT Global sat 338
1. Can I turn on the BT GPS without going into Blue Tooth Manger on the XDA system
2. When I nrecive a call on my BT parrot system the GPS drops out so I have to do a re start sould it do this
Thanks _________________ JohnLittleton |
lbendlin Pocket GPS Staff
Posted: Tue Oct 25, 2005 6:02 am Post subject: |
1) yes, define the 338 as the default SPP device - search this forum for BT BrowserEnabled
2) this is a "feature" of TomTom - you can try version 5.100 but it didn't fix the issue for me... (I have different hardware) _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Tue Oct 25, 2005 9:19 am Post subject: |
I ended up just using the wired GPS with the XDAIIs, that way I had no problems with the BT headset, it all worked fine, there is a new ROM, and Radio stack avail from O2 for this device (it came out end of last wek), as it does a major upgrade to the Bluetooth side you should consider loading that, unless you have already done so - I assume its an O2 device?.
For some of the other traits of the IIs have a read through http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=28396
Cheers Mike |
peterc10 Frequent Visitor
Posted: Tue Oct 25, 2005 3:16 pm Post subject: |
I am not sure the second problem is a TT5 "feature". I have an Ipaq 6340 (phone & PDA) running PPC 2003 qnd TT5 with a Parrot CK3300 combined BT car phone kit and sat nav receiver. When I receive a call using the Parrot kit the sat nav continues in the background and reappears when I hang up. |
Posted: Tue Oct 25, 2005 4:45 pm Post subject: |
I have a 6315 and when a call finishes TomTom loses the GPS connection. _________________ Lutz
Posted: Tue Oct 25, 2005 6:11 pm Post subject: |
The IIs works fine with a BT headset and wired GPS, no drops in GPS connection, TT just mutes the directions while on the phone, it comes back on once you terminate the call - I have never experianced problems with traffic reception either - it just all works fine - mike |
Posted: Tue Oct 25, 2005 6:29 pm Post subject: |
mikealder wrote: | The IIs works fine with a BT headset and wired GPS, no drops in GPS connection, TT just mutes the directions while on the phone, it comes back on once you terminate the call - I have never experianced problems with traffic reception either - it just all works fine - mike |
Mike this is the same with mine except instead of a BT headset I use a BT car kit (Parrot). My sat nav receiver is part of that kit but has a seperate BT connection. It may have something to do with the fact that in TT5 I installed it as a wired serial receiver even when it was not. Or maybe the BT connections (phone and sat nav receiver) on the Parrot just work together better. |
