linrew Regular Visitor
Posted: Sun Oct 23, 2005 9:41 pm Post subject: |
Quote: | Since I am having trouble finding anyone selling the USA maps on CD |
hi
there is nothing to stop you copying the sd card to pc then to go700 but if you want to look for maps on cd the tomtom part no is "1C90.086S". this comes as 9 cds with tomtom 5 software.. it says tomtom navigator 5 on the sticker on the box but the printing on the box says go,navigator5 or mobile5.
i have seen part no 1C90.085 (maps of USA) on sale in the usa for 125dollars but i have no idea if it will work on the tomtom go
the only benefit i can see is that you can load either a single state or group of states or whole of the USA with the cds but only the whole of the USA with the sd card
linrew |
lbendlin Pocket GPS Staff
Posted: Sun Oct 23, 2005 10:32 pm Post subject: |
linrew wrote: |
v5 maps are device independent and can be used with any v5 TomTom product. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
DavidHobbs Regular Visitor
Posted: Mon Oct 24, 2005 10:23 pm Post subject: Re: USA maps on SD card with TTG 700 |
adamkodish wrote: | Since I am having trouble finding anyone selling the USA maps on CD in the UK, is there any reason why I cannot buy USA maps on the 1Gb SD card, transfer these to a PC using a card reader and then on to the TTG700 using the USB cable?? |
You're planning on bringing your GO 700 with you when you come to the States? I assume you'll use it in a rental car. When are you coming? |
adamkodish Occasional Visitor
Posted: Thu Oct 27, 2005 3:39 pm Post subject: |
The USA maps on SD card arrived today.
I copied the map files from the SD card to the PC drive, then back to the TTG700 using the USB lead.
There's still 5Mb spare on the TTG700 and after activation, the USA maps work fine. |
Posted: Thu Oct 27, 2005 6:34 pm Post subject: |
adamkodish wrote: | There's still 5Mb spare on the TTG700 |
Uh, that's not very much... try deleting some of the voices you will never use. _________________ Lutz
Posted: Sat Oct 29, 2005 1:00 pm Post subject: |
A question about map activation:
I've got Europe and USA maps on the TTG and both are activated.
What happens if I delete a map using the built-in menus and then copy it back later from the PC hard drive. Will it TTG know its activated or does it have to be re-activated? |
thomas1711 Occasional Visitor
Joined: Oct 19, 2005 Posts: 9 Location: Northumberland ( U.K. )
Posted: Sat Oct 29, 2005 1:46 pm Post subject: |
adamkodish wrote: | A question about map activation:
I also have the 700 and I have the Europe + the USA maps on mine Im off to the states next week but when I get back I was thinking about deleting the USA map to save abit of space is there a limit on how may times you can activate a map
I also had a city map on I deleted it with the built in menu however when I checked the hard drive with the pc the map was still on the harddrive |
46jimbo Regular Visitor
Posted: Sat Oct 29, 2005 1:57 pm Post subject: |
Once you get your activation code from ttcode.com, write it down. You can use it as often as you have to if you ever have to reactivate the map. You will never have to go back to ttcode.com.
As for the deleted map, the TTG leaves the map folder, but it should be empty, or contain just a couple of small files. |
Posted: Sat Oct 29, 2005 2:08 pm Post subject: |
46jimbo wrote: | Once you get your activation code from ttcode.com, write it down. You can use it as often as you have to if you ever have to reactivate the map. You will never have to go back to ttcode.com.
Thanx for the info 46jimbo :D
I have all codes etc backed up
Regards |
TuurG Frequent Visitor
Joined: Nov 23, 2004 Posts: 454 Location: Haarlem, The Netherlands
Posted: Sat Oct 29, 2005 2:46 pm Post subject: |
46jimbo wrote: | As for the deleted map, the TTG leaves the map folder, but it should be empty, or contain just a couple of small files. |
It leaves your configuration files, or actually anything that was added later (like POIs). |
Posted: Sat Oct 29, 2005 4:57 pm Post subject: |
Luckily I retained the activation code for the USA maps!! |
martin99 Occasional Visitor
Posted: Fri Nov 18, 2005 10:24 pm Post subject: USA Maps and GO 700 |
If you get the USA maps on 1Gb SD card is it possible to isolate the states you need to save space on the drive? I have experience of Navman European software and it was easy to see which country a groupe of files refered to.
Also just to clarify is the Navigator 5 CD set of USA maps part number 1C90.085 compatible with the GO700?Do you need to be on line to activate the maps?And I think it has been said this way you have the USA on 9 CDs so you can load as much as you need.
From INKINO web sales site:do both of these work with GO 700?
TomTom GO Maps of USA
Ref No : TTG009
Manufacturer Code : 1D90.081
Price : £119.95
Shipping : £5.00
TomTom Navigator 5 Software + Maps of USA/Canada
Ref No : TTN5SWUS
Manufacturer Code : 1C90.085
Price : £149.95
Shipping : £5.00
Many thanks |
Posted: Sat Nov 19, 2005 12:08 am Post subject: |
If you get the 1GB SD card version then you cannot split maps out - it';s one large chunk.
If you've got the CDs you can install smaller map pieces.
Any map will work with any device. _________________ Lutz
mindfull Occasional Visitor
Joined: Aug 04, 2005 Posts: 4 Location: San Francisco Bay Area
Posted: Sun Nov 20, 2005 5:53 am Post subject: THe issue is cigarettes, not charging... |
clem wrote: | Hmm. Emailed dollar and got this response:
"XXXX,
The cigarette lighters would be enabled as persons use them to charge their cell phones.
If you have any other questions, feel free to e-mail us.
XXX
Dollar Internet Help Desk"
I guess the best thing to do is to take both chargers. I'm not sure my PDA would survive a 4 -6 hour drive without charge so the cigarette lighter working is a must! |
The issue here is the cigarette lighter "plug-in" that has been removed from nearly all rental cars. The actual socket, for charging phones, nav, radar detectors, laptops, or whatever else you can think of is still there & very much active.
It's a small distinction, but will save you hefting around more chargers than you need. The auto industry trend is actually to provide more sockets, not less... My BMW has always had 2 sockets (front dash & mid-seat console), but I was pleasantly surprised to find the same in the 2006 Toyota I rented last. But FYI, there were no cigarette lighter plugs, just 12V sockets with cover plates over them when not in use.
Hope this helps.
M _________________ From the Desk of:
Mindfull
SF Bay Area Real Estate Consultant
Treo & TabletPC~ A match made very close to Heaven!
Now Enjoying the TomTomGO 700 GPS Nav!! |
dieselduck2000 Occasional Visitor
Posted: Tue Nov 29, 2005 5:36 am Post subject: E-bay maps |
OK, as you can see here, I am new to the site, and also a new owner of a TT300. Pardon my ignorance, but how can one be sure that the maps have been activated (the ones sold on E-bay), and not just copied on the SD before they were sold, as "virgin" maps ? How can I check if they are genuine or "used" ? Thank you. |
