chrisb1357 Occasional Visitor
Joined: Aug 30, 2005 Posts: 32 Location: Leicester, UK
Posted: Wed Oct 19, 2005 9:45 pm Post subject: POI Problem In Tom Tom Navigator 5.10 |
Hi all,
I wanted to know if there is a limit on how many POI's that can be installed and used in TomTom Navigator 5.10 for the Pocket PC, I have just installed some new POI's and most of them show up apart from a few which for some reason wont show. I have checked to see if they are installed on the SD Card ok and they are.
Any Help Would Be Great,
Many Thanks
Chris B |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10643 Location: Suffolk, UK
Posted: Wed Oct 19, 2005 10:04 pm Post subject: |
I believe there is a limit of 40. _________________ Richard
Posted: Wed Oct 19, 2005 10:08 pm Post subject: |
Is that 40 Installed or does it only count as 40 Which are Enable.
Also does it count the default poi's which come with tomtom
Chirs |
Posted: Wed Oct 19, 2005 10:29 pm Post subject: |
It's 40 that are user added, and TT will only see that number, even if they are not enabled.
It does not include the TT built-in categories. _________________ Richard
Posted: Wed Oct 19, 2005 10:31 pm Post subject: |
Does it count my Home Location which is set and also my Favourites,
Chris |
Posted: Wed Oct 19, 2005 10:36 pm Post subject: |
No they don't count as POI's. _________________ Richard
Posted: Wed Oct 19, 2005 10:40 pm Post subject: |
Just Checked my SD Card under the Belguim Map and i have installed 37 POI's for Belguim and there is only 34 Showing in the POI Menu in TomTom, There is no other maps installed as this is my SD card which i have for bulguim roads.
Chirs |
Posted: Wed Oct 19, 2005 10:49 pm Post subject: |
I wasn't aware that the Belgium map would be any different.
Perhaps the limit on that map is 34 seems strange though. _________________ Richard
Posted: Wed Oct 19, 2005 11:21 pm Post subject: |
i have just checked CheckPoint POI Software and that shows the coorect amount of installed POI's
Something strange i think
Chirs |
Posted: Thu Oct 20, 2005 10:01 am Post subject: |
Does anyone else have any info on the above
Chris |
![](modules/Forums/images/avatars/32928398450ec149ec6abd.gif)
Joined: 30/12/2002 17:36:20 Posts: 4914 Location: Oxfordshire, England, UK
Posted: Thu Oct 20, 2005 12:16 pm Post subject: |
Hi chrisb1357,
The maximum number of POIs that you can currently load into each map in TomTom Navigator 5 is 39 user custom ones, plus all of the default TomTom ones.
All of the default POIs are effectively classed as one (as they are in the POI.DAT file). This is why you see the figure of 40 quoted a lot (39 + 1 = 40).
Garmin Camper 770 LMT-D |
Posted: Thu Oct 20, 2005 2:37 pm Post subject: |
OK i have checked my SD Cards again and he what i have below:
256MB SD Card - UK Maps - 39 User POI's + Default POI = 40
(Thats Fine)
128MB SD Card - Belguim Maps - 34 User POI's + Default POI = 35
(If i install more POI's under this map they do not show up in the list of POI's and only the current 34 and the default poi's show up. I now went into the Add POI Category under the manage POI menu in tomtom just to test if i can add a category via tomtom, When i try this i get 'No room for more categories' with a red backgound and a continue button at the bottom. I click this and it takes me back to the Manage POI menu,
Does anyone know why this is and is the limit on the tomtom belguim maps the same as the UK one
Many Thanks
Chris _________________ IPAQ 2210,
TomTom Navigator v5.100, GPS Driver v1.20
Orignal TomTom Wired GPS Receiver
256MB SD Card with Great Britain Plus Map
128MB SD Card with Belguim Map
Checkpoint POI v5.0.2.0
Pocket GPS UK SpeedCams
POIHandler France & Belguim SpeedCam |
Wes Occasional Visitor
Joined: Oct 24, 2005 Posts: 2 Location: Somerset, England
Posted: Mon Oct 24, 2005 2:04 am Post subject: Help |
Hi, Could anyone please assist me?
I am currently running Tom Tom 5 on my HP iPAQ 5550. I have downloaded points of interest from this site, have saved them to my P.C. I have then unzipped the files and have then transferred them to the Great Britain Plus file on my storage card. I have then opened Tom Tom and gone to the manage P.O.I.s and then to enable but there is no trace of the updates. I have then gone add POI and again the update is not there. I have then gone to add POI category, have typed the title of the upgrade in to be told that it already exists.
I have then downloaded the POI editor from the link on your site and have tried to run it using this system but with the same results.
If I browse the file on my P.C. using the activsync the relevant files are in place.
I have evem deleted one category to no avail.
Can anyone shed any light on where I am going wrong or offer some advice please.
Kind Regards,
Wes |
Posted: Mon Oct 24, 2005 9:05 am Post subject: |
Welcome Wes, Have you loaded the correct files there are two per camera a .ov2 and .bmp - they go into the Great_Britain_ map folder on your SD card, you must ensure the files are extracted from the unzipped folders before copying them to the SD card. Then select prefferences, manage POI and enable/ disable - Cheers - Mike |
Posted: Mon Oct 24, 2005 6:34 pm Post subject: |
mikealder wrote: | manage POI and enable/ disable - Cheers - Mike |
Mike - wouldn't Warn When Near be better than Enable/Disable as Enabling slows down Map Re-drawing on some PDA's? _________________ Richard
