Pocket GPS World :: View topic - H6340 not picking up tomtom navigator 5
me__2001
PostPosted: Sun Oct 23, 2005 9:24 pm    Post subject: H6340 not picking up tomtom navigator 5 Reply with quote
i've just bought the tomtom navigator 5 and the software has installed but i cant pick up the reciever. i have tried to add the reciever by following this guide
http://www.aximsite.com/bluetooth/bt_guide2.htm#section5
but the ipaq just keeps searching, does anyone have any idea why it cant be found ?
also the reciever is detected by my PC but i cant find the Ipaq using it Confused
me__2001
PostPosted: Sun Oct 23, 2005 10:14 pm    Post subject: Reply with quote
after searching the site i tried setting it as a serial device with a 38400 baud and have gone through all of the ports that are availabel and it still cant be picked up, have also tried both a hard and soft reset
alix776
PostPosted: Sun Oct 23, 2005 10:50 pm    Post subject: Reply with quote
what receiver is it
device Lumia 950 xl
me__2001
PostPosted: Sun Oct 23, 2005 11:26 pm    Post subject: Reply with quote
tomtom wireless GPS Mk II
PostPosted: Sun Oct 23, 2005 11:48 pm    Post subject: Reply with quote
Is the GPS unit actually paired with the the PDA - it should show a couple of small green arrows under the icon (it needs to be SSP mode), once active and paired try setting the GPS in TomTom to other NMEA cabled devices, go for the correct Baud speed for your device, then select the correct bluetoth port from the options displayed (I know its a BT device and seems stupid selecting other wired - but give it a go) - finally make sure the GPS has a clean line of sight to the sky and give it ten min (minimum) to sinc up with the data (monitor the progress on the GPS setup screen you should see some activity after a while) - it will only need this ammount of time the first time, after this 20 - 30 seconds is about right - Mike
me__2001
PostPosted: Sun Oct 23, 2005 11:51 pm    Post subject: Reply with quote
no, thats the problem i cant get the Ipaq to even pick up the reciever so i can pair them
PostPosted: Sun Oct 23, 2005 11:56 pm    Post subject: Reply with quote
Is the unit in discovery mode, most units do this for about a min. and it is this period you need to pair the device, it is usually put in this mode at start up so go for a pair at this point - once the pair is achieved the rest is easy - no pair and no sat nav I am afraid - but this highlights where the problem actually is - Mike
me__2001
PostPosted: Sun Oct 23, 2005 11:58 pm    Post subject: Reply with quote
i think the bluetooth may be screwed as it wont turn on anymore Crying or Very sad
me__2001
PostPosted: Sun Oct 23, 2005 11:59 pm    Post subject: Reply with quote
i try to find the device using the guide linked to in my first post
PostPosted: Mon Oct 24, 2005 12:00 am    Post subject: Reply with quote
Check PM
Mike
PostPosted: Mon Oct 24, 2005 12:04 am    Post subject: Reply with quote
Is it rechargable, or does it take batts, replace/ recharge if necessary they don't generally die that easily, once up and running we can carry this on - Mike
me__2001
PostPosted: Mon Oct 24, 2005 12:06 am    Post subject: Reply with quote
the reciever is rechargeable but is fully charged as is the Ipaq
PostPosted: Mon Oct 24, 2005 12:09 am    Post subject: Reply with quote
Is there a reset button recessed on the case for the stylus to prod, if not then its possibly taken a trip skywards - unusal for a new device
me__2001
PostPosted: Mon Oct 24, 2005 12:15 am    Post subject: Reply with quote
the Ipaq is about 2months old and the GPS reciever was bought today, yes there is a reset button and i have performed a soft reset and a hard reset multiple times
PostPosted: Mon Oct 24, 2005 12:22 am    Post subject: Reply with quote
Does the PDA actually see the device at all (turn the GPS unit off then back on before trying this bit) - when in search mode, the explore BT Devices should spin the blue icon top left and then find the GPS unit, at this point select it, retrieving services will be displayed - at this point you select SPP mode, followed by finished. then the icon that is displayed needs to be tap and hold, then select connect from the pop up box, at this point you should get the two small green arrows and can then use it in TT - Mike
22.094 (25 Sep 24)
