Posted: Mon Oct 03, 2005 1:34 pm Post subject: help loading speed camera on pda!!!
Please can somebody talk me through how to load speed camera on my pda dell x5, i have managed to load the tomtom navigator 3 on but i cant figure out how to load the speed camera's on it. when i bought the pda it was working, but it went flat and lost all the info, so now i have to reload everything, cant understand why it goes flat witin a week of not being used though, anybody else had the same problem? thanks a lot.
Joined: Aug 21, 2005 Posts: 617 Location: Gloucester UK
Posted: Sun Oct 23, 2005 5:22 pm Post subject:
Hi Tont, When you switch your PDA off, power is used to store programs etc in RAM, if the battery goes flat, You loose everything in Ram, which is what has happened to you. When you switch your PDA off, make sure all running programs are closed, or they will continue to run in the background, even when the PDA is off. Finally, It may be wise to invest in "sprite Backup" you can backup your PDA, in an " exe" file, and store it on an SD card or similar, so if you loose everything from your PDA, clicking on the "exe" file will restore everything. I have a 60 day trial vertion at the moment, check it out here.
Posted: Sun Oct 23, 2005 5:50 pm Post subject:
For the actual warnings to work you will need checkPOI from this site (downloads) from home page, rh side. Get the correct version applicable to the tt vs you are using - cheers, mike
Posted: Sun Oct 23, 2005 5:52 pm Post subject:
