Pocket GPS World :: View topic - Ipaq / TTN2 & SD cards
mark.peters
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: Ipaq / TTN2 & SD cards Reply with quote
Anyone else using the above combo ?
Getting no end of problems with mu Ipaq now refusing to recognise the Sandisk SD card that I have !
Got a work colleague who has the same set-up and his has also gone t*ts up as well ... he's using 'Pretec' & 'KingMax' SD cards !
HP have advised me to do a hard reset - which apart from clearing my machine of all installed software - done nothing else ! Still got the same problem !
Mark
There are known issues with specific SD cards for compatibility issues, Sandisk appear to be one of the more problematic cards. I use Integral which are pretty good on the iPAQ's.
I have had the problem before where a card has been working perfectly okay for months on end, then suddenly it stops working but put it into other iPAQ's or card readers and it's fine, and a hard reset has cured the problem. Sometime's the Pocket PC's can get to a stage where they're completely confused and won't recognise insertion of any SD cards. Only recourse at this stage is to hard reset.
gstenson
check your firmware version of your PPC, sometimes causes problems with SD cards. I found that my Sandisk card went like this...I emailed Sandisk and they offered to replace it via the warranty. Not bad considering I bought it on eBay Smile
minesapint
if its the 3970 or 3975
there is a sd card driver update
try looking at
http//h18007.www1.hp.com/support/files/handheldiPAQ/us/locate/71_4704.html
DavidW
An equivalent update has been produced for the 3950/3955 running ROM 1.11 - which contains the same flawed SD drivers.
Download that one here.
Make sure you pick the right upgrade for your hardware - 395x or 397x and that you have the right ROM version installed before following the other instructions.
Neverlost
Had a similar problem in that the SD card was OK for a month or so before becoming unrecognised. Returned the IPAQ 3970 to HP, they replaced the motherboard FOC. Apparently there are some units out there with a known hardware defect.
Unit now works 100% for over 6 weeks.
