stevengirdham Occasional Visitor
Posted: Mon Oct 17, 2005 9:24 pm Post subject: TT5 XDA EXEC |
Does tt5 work with the new xdx exec with windows mobile 5. and can i activate it again |
Posted: Thu Oct 20, 2005 8:54 pm Post subject: |
has nobody but me got the new xda exec |
andy-c1 Lifetime Member
Joined: Feb 05, 2005 Posts: 1039 Location: East Sussex
Posted: Thu Oct 20, 2005 9:31 pm Post subject: |
this has been covered before ...
what you have to do is copy the cab files across & run from your ppc _________________ TomTom 5001 |
alix776 Pocket GPS Moderator
Posted: Thu Oct 20, 2005 10:31 pm Post subject: |
yes tt5 will run on a exec and you will be able to activate it as long as your still within the 3 activation limit which is one initial acivation two second after seven days and 3 six months later other than this you'll have to get intouch with tomtom for an activation code _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Sat Oct 22, 2005 1:07 am Post subject: |
could you tell me what you mean copy cab files across & run from your ppc |
Posted: Sat Oct 22, 2005 1:38 am Post subject: |
put the sd card in to the slot and the go to the storage card then to the 2577 file this all done on the exec and click the ttn,ppaddin gps and wzd files to install tt5 _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Posted: Sun Oct 23, 2005 8:14 pm Post subject: |
Tanks done what you said has installed ok. but now how d i install the 5.1 update.plus i cannot get full post code to work,tryed to copy it to my documents but will not let me |
Posted: Sun Oct 23, 2005 8:23 pm Post subject: |
For the postcodes to work use the file explorer on the PDA and make sure the Zip folder is in the root of the SD card, also create an empty folder named "tomtom" (use lower case - and don't try putting the quotation marks on either) - this way works for me, I did try the MyDocuments route as advised from the TomTom web site but it is a gross waste of memory - I can't take the credit for this as Darren highlighted it to me earlier this weekend - Mike |
Posted: Mon Oct 24, 2005 7:54 pm Post subject: |
Tankyou mikealder
i did what you said,now works ok.do you know how to install the update 5.1.plus what do you think to the xda exec could have done with a lot more Memory and a update to make wm5 more stable |
Posted: Mon Oct 24, 2005 8:13 pm Post subject: |
Steven, Glad you got it working (Thank Darren for the info I just passed it on), so far I haven't put 5,1 on the unit - still trying it in vs5,0 just to see what happens, as to the Exec - I like it and yes more memory is always usefull but so far its not an issue (for me - but it might be when I start to use it fully), the only thing I would really like is a slot for CF cards in addition to the SDIO, that way I could use some of my more exotic cards Digital MultiMeter and data Acquisition devices - they are confined to the 4700 at the moment, otherwise its a nice bit of kit - Mike |
