Synth Regular Visitor
Joined: May 14, 2005 Posts: 78 Location: Perth, WA, Australia
Posted: Sun Sep 04, 2005 12:17 am Post subject: Battery fading |
I work on ships so I frequently am away for several weeks at a time. I find that when I get home the battery on my Navman is completely flat and I have to charge it in the car or with the main supply to bring it back to life.
Has anyone else noticed this, or do I have a duff battery? |
RonS Occasional Visitor
Posted: Sun Sep 04, 2005 10:05 am Post subject: |
Do you use the switch at the back of the unit to disconnect the battery, or do you only turn it off using the keypad? If you only use the keypad, then charge is still being taken from the battery in a 'standby' mode.
Ron |
Posted: Mon Sep 05, 2005 10:56 pm Post subject: |
Thanks for the tip. I'll do that the next time I put it aside for a month or two. |
Posted: Sat Oct 22, 2005 12:36 am Post subject: |
Last trip was just under a month. The Navman switch was set on off and it was working when I turned it back on. Thanks again for the tip. |
