Pocket GPS World :: View topic - Keeps trying to connect to my Bluetooth chip on
Wizzo
PostPosted: Sun Oct 16, 2005 11:24 am    Post subject: Keeps trying to connect to my Bluetooth chip on Reply with quote
I like to plan my routes before I go out but it’s a pain Evil or Very Mad when tomtom keeps trying to connect to my Bluetooth chip on. How can I stop it keep trying to connect is there a registry fix like with ver 3 ?
Ipaq 5500
Fortuna Clip-On Bluetooth GPS
Tomtom 5.1
RobStevens
PostPosted: Mon Oct 17, 2005 3:13 pm    Post subject: Reply with quote
That's strange. For me, this was one of the improvements in TT5. TT3 immediately bombed out if it couldn't talk to the Clip-On, so I had to have it handy whenever I wanted to browse the map. TT5 runs without it on my HP iPAQ 4150. It also switches Bluetooth on automatically, something I often forgot to do previously.
StevePritchard
PostPosted: Mon Oct 17, 2005 3:39 pm    Post subject: Reply with quote
Not sure if this is your issue, i.e. you can't plan a route unless you have a connection to the GPS...?
You can get around this limitation by choosing Advanced Planning, and specifiying a start and end point. It will then calc a route without needing a GPS signal.
Cheers,
Steve.
aliendad
PostPosted: Mon Oct 17, 2005 3:46 pm    Post subject: Reply with quote
Mine is just happy to sit there with "No GPS device!" at the base of the map, doesn't keep searching, and as has already been said, use advance planning, and start from home.
Wizzo
PostPosted: Mon Oct 17, 2005 7:43 pm    Post subject: Reply with quote
Thanks - Yes i can plan with Advanced Planning no problem but the bluetooth keeps poping up and tries to connect I have to keep pressing cancel each time it pops up, eventually it gives up ! any idea how I can stop it trying to connect.
aliendad
PostPosted: Mon Oct 17, 2005 8:26 pm    Post subject: Reply with quote
sounds like you only have the bt gps set up in tomtom, and the pda may need the bt & pda set as a secure conection?
this is a thought, maybe no use at all
nigelw
PostPosted: Tue Oct 18, 2005 1:42 am    Post subject: Reply with quote
Don't press Cancel. Select the device and it will fail to connect, then go silent.
If you only have one BT device, make it the default then the selection dialog will never appear again, at least that's what happens on my Axim. TT5 does this by default if you tell it to use "Other BT device" rather than "cable device", or whatever (I'm not running TomTom atm and don't want to mess up the BT settings just to get the correct wording).
Wizzo
PostPosted: Tue Oct 18, 2005 5:43 pm    Post subject: Reply with quote
Tanks nigelw,
That did the trick
deesoft
PostPosted: Tue Oct 18, 2005 11:59 pm    Post subject: BT Gps and TTN5 Reply with quote
I had the same problem till I installed TTN5.1 and Bing the problem went away.
Ipaq hx2750, TTN5, Globalsat 338 GPS, Garmin Nuvi 310D and GTM12, TomTom GO910 and now GO540
God gave us the Integer, the rest was devised by man.
22.124 (26 Dec 24)
