Pocket GPS World :: View topic - gatso not showing on screen navman icn 520
roadnobler
PostPosted: Thu Oct 13, 2005 9:32 pm    Post subject: gatso not showing on screen navman icn 520 Reply with quote
just installed the speed camera database on my navman icn520.
But I slipped up on the gatso cameras.
I forgot to increase the poi visibility on the slider, until the second set of cameras, the other ones show up fine,temps redlight etc
How do I go about redoing the gatso section so I can see the icon...stuck
cheers
Dilemma
PostPosted: Thu Oct 13, 2005 10:25 pm    Post subject: Reply with quote
The POI visibility slider is merely a filter and is only there so that if you are in an area where there are large ammounts of POI's which would ordinarily be visible and clutter the screen, the highest visibility POI's will be more visible than the lower ones. Accordingly, every POI will still be visible, and has nothing to do with your unit not displaying a Gatso POI icon unless there are other POI's in the immediate vicinity.
I set have the speed zoned POI's loaded with maximum visibility, and have the red light cameras asd Gatso cameras set at 75%, followed by congestion charg entry points set at 50%, and every other POI (petrol stations etc) set at minimum visibilty. Every POI I have loaded including those set to 0% are still visible.
Do not confuse the visibility slider with the other check boxes. These will:
either display a banner if the 'Visible Warning' check box is ticked, and play an audible alert if the 'Audible Warning' check box is ticked, and then only then if the 'Active' check box is ticked.
If you are in any doubt, delete the POI file and reload it at the desired visibility.
