wildey Occasional Visitor
Posted: Thu Oct 13, 2005 12:34 am Post subject: What Voice Prompts should I expect ? |
Hi All,
I've just bought my first ever Sat Nav - the i3, and the first thing I did was to upgrade to v2.60, and I've just been out for my first test drive.
Now everything looks really neat, and works well, but I have questions over the voice prompt. I wasn't getting the forward info I would expect. For instance when at roundabouts it just went "Enter 2nd Exit" and once on a main road just went "Drive". It didn't seem to tell me about 200 metres away from turns that I should be ready to do so etc.
Is it me or is this part of it a bit naff ?
Or more likely is there a setting I need to change ?
Please help, this one little thing is annoying me !!!
Also, if you want to help then is there an easy way to display all the POI's on the screen or even a selection of them ?
Many Thanks Guys and Gals
Chris |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15154 Location: Bradford, West Yorkshire
Posted: Thu Oct 13, 2005 10:13 am Post subject: |
and if you can't be bothered to look then just change the voice language (in settings) to something else, then change it back to english AND WAIT until it loads fully.
MaFt |
Posted: Thu Oct 13, 2005 12:44 pm Post subject: Thanks for help..... |
Thankyou for that tip. Even though it was late i did look through the thread and found the answer.
It seems to be working now, however I'm a bit confused that when I approach a turn it doesn't tell me any distance warnings, i.e. turn left in 300 yards and when I get to a turn it says "turn right (as expected), then turn left".
Is it predicting the next turn or is it still not functioning properly ? |
Posted: Thu Oct 13, 2005 12:53 pm Post subject: Re: Thanks for help..... |
wildey wrote: | Thankyou for that tip. Even though it was late i did look through the thread and found the answer.
if it's 2 turns in quick succession it will just say turn left then turn right i.e. straight away. if it does it at the same place each time then i guess that's why. if it says it at every turn then that's a bit strange... |
Posted: Thu Oct 13, 2005 12:55 pm Post subject: .. |
and should it give me distance warnings, ie. turn off or turn left in 300 metres ?
Thanks for your help. |
zogman Frequent Visitor
Joined: Sep 05, 2005 Posts: 1417 Location: swindon uk
Posted: Thu Oct 13, 2005 1:05 pm Post subject: Re: .. |
wildey wrote: | and should it give me distance warnings, ie. turn off or turn left in 300 metres ?
firmware version 2.4 did , but the new versions dont which feel is much better.. _________________ *************************** |
Posted: Thu Oct 13, 2005 1:45 pm Post subject: Re: .. |
wildey wrote: | and should it give me distance warnings, ie. turn off or turn left in 300 metres ? |
not if the turn is imediately after another one.
it could say 'in 0.8 miles turn left then turn right' then as you near the turning it would say 'turn left then turn right' then sometimes it might quickly say 'turn right'
this only tends to happen when turns are very close together though. if the 2 turns are quite far apart you will get a distance for the 2nd turn.
MaFt |
BERT_UK Occasional Visitor
Posted: Thu Oct 13, 2005 2:56 pm Post subject: Re: .. |
zogman wrote: | wildey wrote: | and should it give me distance warnings, ie. turn off or turn left in 300 metres ?
firmware version 2.4 did , but the new versions dont which feel is much better.. |
I'm using version 2.5 firmware and distance warnings are given. I think you may need to reinstall the voice files if this isn't working.
It may be worth doing a full reset (also mentioned earlier on in the thread) as well to ensure any old voice data files are removed.
On my initial installation the voice files didn't fully load and voice prompts (particularly distance prompts) were very erratic. A full reset and voice reinstall cleared this up. I believe the new firmwares have a progress bar when the voice files are being installed, but I haven't reinstalled since these new releases so don;t know if you are forced to wait.
Good luck. |
Posted: Thu Oct 13, 2005 4:40 pm Post subject: |
just to clarify..version 2.0 gave out distances in feet when approaching turns etc...version 2.5/2.6 gives out distances in point of a mile ie ''point 5 miles to roundabout''.... _________________ *************************** |
Thomas_Quest Occasional Visitor
Posted: Thu Oct 13, 2005 11:27 pm Post subject: |
i just noticed that my garmin has speed warnings and traffic light warnings integrated into the original maps (switzerland/austria).
every time my route crosses a Safety Camera, the top bar changes to red and indicates the speed limit or a traffic light with camera.
you also get an acoustic warning
pretty cool feature.
best regards
Quest |
pushandpull Regular Visitor
Joined: Sep 12, 2004 Posts: 153 Location: Heywood, Lancashire
Posted: Sat Oct 15, 2005 11:18 am Post subject: |
Thomas_Quest wrote: | i just noticed that my garmin has speed warnings and traffic light warnings integrated into the original maps (switzerland/austria).
best regards
Quest |
If you have the UK camera database loaded it also does this on the UK map. If you're exceeding the speed limit it also gives continuous "boings" until you slow down which is pretty cool !
pauljmuk Occasional Visitor
Posted: Sat Oct 15, 2005 12:14 pm Post subject: |
I suspect Garmin dont want to go down the route of loading cameras onto UK version for a few reasons
1. They constantly need updating, or become useless
2. There is currently talk that the Commons are going to try to ban snoopers and the like from being used _________________ Pauljmuk ::::
DSL - Don't Say Leonard |
Jaz666 Lifetime Member
Joined: Aug 10, 2005 Posts: 88 Location: Clitheroe, Lancs
Posted: Sat Oct 15, 2005 12:57 pm Post subject: |
pauljmuk wrote: |
2. There is currently talk that the Commons are going to try to ban snoopers and the like from being used |
Not quite correct...............
Only Laser speed gun detectors are being outlawed. Older models of Snoopers and Road Angels will still be legal to use, as there is an option to disable the laser detector. |
kevinbev Occasional Visitor
Posted: Sat Oct 15, 2005 1:23 pm Post subject: |
Having a fiddle about with the i3 the other day, went onto the main page about to alter the settings, and the whole thing locked up (v2.5). Already being a bit peeved about the new map update coming out shortly and not being able to update free of charge I took the opportunity of taking the unit back to PCW with the batteries still in and unit still on. When checking contents counter staff asked where the cd was to which I replied there wasnt one. "There should be it states on the box". Anyway after they checked another unopened unit they realised that what it states on the box is not necessarily what you get. Offered the new unit or refund so took refund for now. Hope I dont have to wait too long for the mapping updates so I can get another. |
Willie_Ekaslike Occasional Visitor
Joined: Oct 10, 2005 Posts: 20 Location: Watford, Herts
Posted: Sat Oct 15, 2005 1:37 pm Post subject: |
Ordered mine on-line fron Maplins and it came with a CD (not sure what is on it other than the usb drivers) Will look when I get home... _________________ Willie ~0^0~
ERROR: Keyboard not attached, Press F1 to continue. |
