Sun4u Occasional Visitor
Posted: Wed Oct 12, 2005 1:35 pm Post subject: |
I would like to see a debug mode or at least some more details whats happening!...yesterday it took 25 mins to acquire satellite....I was completely lost and very crossed.
Usually, it just take few seconds to acquire satellite! |
zogman Frequent Visitor
![](modules/Forums/images/avatars/4129001634330026455503.gif)
Joined: Sep 05, 2005 Posts: 1417 Location: swindon uk
Posted: Wed Oct 12, 2005 1:45 pm Post subject: |
sun4u...i've noticed this as well, not with the i3 but with a 60c i had and by chance my sky dish signal was breaking up as well...i can only think that if theres really bad weather up in the ionsphere the signal cant get through ...thats my theory half baked as it is.. _________________ *************************** |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15157 Location: Bradford, West Yorkshire
Posted: Wed Oct 12, 2005 1:48 pm Post subject: |
zogman wrote: | sun4u...i've noticed this as well, not with the i3 but with a 60c i had and by chance my sky dish signal was breaking up as well...i can only think that if theres really bad weather up in the ionsphere the signal cant get through ...thats my theory half baked as it is.. |
sounds plausible though - afterall you're getting info from a satellite that's a few hundred miles up in the air as opposed to a few miles away at the top of a building (for mobile phone signals).
what info did you want sun4u? it said it was acquiring satellites - would you want to see all the algorithms is goes through to acquire them?
MaFt |
Posted: Wed Oct 12, 2005 2:23 pm Post subject: |
it just stuck at "acquiring satellite..."
when you are indoor, it prompts for confirmation "...are you indoor.." , while yesterday it didn't prompt, it means there were some signals...so...at least the signal strenght...
MaFt wrote: |
MaFt |
Posted: Wed Oct 12, 2005 2:30 pm Post subject: |
sounds like a small firmware crash....just wondering if you had turned the unit off and then on if it would have got a lock..... _________________ *************************** |
Posted: Wed Oct 12, 2005 2:42 pm Post subject: |
Did that twice !!
First I did in just 5 mins then again in 5 mins then i let it go..after 15-20 mins it found satellite (without re-starting) !!
Weather was clear as well.
zogman wrote: | sounds like a small firmware crash....just wondering if you had turned the unit off and then on if it would have got a lock..... |
andybike Occasional Visitor
Joined: Oct 11, 2005 Posts: 26 Location: warwickshire uk
Posted: Wed Oct 12, 2005 2:46 pm Post subject: |
zogman wrote: | andybike wrote: | i'm a newbie and i have a few idea's.
howabout an earphone socket,a 1'' socket/ball adapter for use with ram mounts and a waterproof case as the i3 is popular with bikers who want a gps satnav on a tight budget |
earphone socket ... for an extension speaker maybe or route sound via car stereo (although the i3 voice directions are quite loud) |
not when you have 120db+ of windblast on a motorway,a 3mm earphone socket would be great |
Posted: Wed Oct 12, 2005 2:55 pm Post subject: |
Sun4u wrote: |
what about radiation further up in the atmosphere? |
Posted: Wed Oct 12, 2005 2:58 pm Post subject: |
Didn't get a chance to check that !!
MaFt wrote: | what about radiation further up in the atmosphere? |
Posted: Wed Oct 12, 2005 3:12 pm Post subject: |
Sun4u wrote: | Didn't get a chance to check that !!
ah well, next time ;)
from here: http://www.gpsw-support.co.uk/faqgeneral.htm
What is TTFF or Acquisition Time ?
The time it takes for a GPS receiver to acquire satellite signals and determine the initial position. You need at least 3 satellite fixes for the GPS Receiver to be able to triangulate it's position, but most will prefer to function on 4-5 or above.
- What should be the average TTFF ?
TTFF's can vary from depending how long the GPS has been off, to local surroundings, interference and ionosphere interference. Please note the times listed below are only as a guideline and should not be guaranteed. Fixes can differ depending on how much Almanac or Ephemeris data is already recorded as current data within the GPS Receiver. Times can also be affected by localised interference, multipath errors (rebounded signals) or external interference like ionosphere interference or solar flares. |
Skippy Pocket GPS Verifier
![](modules/Forums/images/avatars/7197988194d2507f52befb.jpg)
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Wed Oct 12, 2005 7:30 pm Post subject: |
zogman wrote: | i can only think that if theres really bad weather up in the ionsphere the signal cant get through ... |
Generally speaking, the weather and ionospheric conditions do not have a noticeable effect on GPS receivers. If atmospheric conditions were so bad that a reciever couldn't get a first fix for 20 minutes then it would be front page news because there would be an awful lot of people having problems.
The problem with the GPS receiver not getting a fix were probably due to the receiver completely losing it's ephemeris and almanac data and having to do a sky search in an area with poor visibility of the sky or while moving. _________________ Gone fishing! |
Thomas_Quest Occasional Visitor
Posted: Fri Oct 14, 2005 6:07 pm Post subject: |
i think the ability to see the current speed instead of the arrival time should be added.
to toggle between these two info with the power button would be cool, but an option in the settings would also work for me.
that is the feature i miss most.
Quest |
pauljmuk Occasional Visitor
Posted: Sat Oct 15, 2005 12:49 am Post subject: |
Confused as to the apparent majority wanting to see the speed on the i3.... Surely, the speedo in the car is good enough.... (yeah, yeah I know, it aint ever truly accurate, but hey, we're talking 1-5mph)....
As for me - I'd like the abilty to upload saved points I take in the field, to back em up.
That or the postcode thing fixing - then I wouldnt need the saved points, as the locations would work first time!!!!! (my work sites are all without house numbers, and the postcode search is vague to say the least)
Pauljmuk |
Posted: Sat Oct 15, 2005 10:36 pm Post subject: |
crazylegs wrote: | I know this because i nearly hit something the other night cause i was too busy looking at the sat/nav... 8O |
never had that problem. besides, if i monitor the speed on the tacho, im takeing my eyes from the street. if i check the speed on my navi, i'm keeping my eyes where i'm driving.
best regards
Quest |
Posted: Sun Oct 16, 2005 1:01 am Post subject: |
Surely not - if you've been driving for years, glancing at the speedo is second nature surely - its also a big fat needle pointing at a big fat number.
That has to be safer than squinting at a box showing speed that is about 1cm by 0.5 cm.....
Just my two cents - I didnt buy the i3 to tell me my speed, I bought it to tell me how to get to where I'm going. _________________ Pauljmuk ::::
DSL - Don't Say Leonard |
