Pocket GPS World :: View topic - Temporary low volume solution
mumbo
PostPosted: Thu May 19, 2005 6:48 am    Post subject: Temporary low volume solution Reply with quote
I picked up a case this weekend from CompUSA. It's about the size of two PDA cases and has an amplified powered by a 9v battery. It has *plenty* of volume.
IPOD® CASE WITH BUILT-IN POWERED SPEAKER
CompUSA $24.99 Each - $10 Instant Savings
#318576
http://www.compusa.com/products/product_info.asp?product_code=318576&pfp=srch1
mumbo
PostPosted: Thu Aug 11, 2005 7:18 am    Post subject: Reply with quote
Found something I like better. I plug in this small FM transmitter and play the navigation through the radio.
$29.95 from Radio Shack
http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&product%5Fid=12-2054
Gerco
PostPosted: Mon Oct 10, 2005 12:09 pm    Post subject: Reply with quote
I found an interesting box (FastMute) which make it possible to connect ANY PDA to your car speakers(stereo).
No special radio required.
The box has a Mute-Generator (VOX) implemented.
In the moment (5ms later) the internal car speakers are switched off and the PDA sound comes amplified (9W Sin) to your car speakers.
There is only one 2 wire connection, from the ear phone jack to that box.
2 sec after the PDA sound has finished the speaker will be switched back (fall back) to your radio.
If you have a DIN loudspeaker connector just remove connectors from your radio and plug this box in between, connect to earphone output and power it, thats all.
Add On implemented for PDA MP3 users.
Autodetect for music. If the box is detecting music the fall back time will now be changed from 2s to now 15s. So no low volume music will cause any jitter in switching.
You can find this box here
http://www.fastmute.de/
The only problem is, that all informations are in German.
If there is some interest, I can translate the main items
Gerco
22.064 (26 Jun 24)
