Pocket GPS World :: View topic - ScaredyCats Apps Re: Quick Add Camera
jimbokb
PostPosted: Tue Oct 04, 2005 12:04 pm    Post subject: Reply with quote
Of course I am back to having the Quick Cam Add on page 4 instead off page 1 but hey after all the grief that trying to get it on page one has caused I think I will just leave it where it is.
Cheers All
TTG 300,External Aerial
1Gig Viking SD, 512 Viking SD(Backup)Nokia 6680 (o2), 512 MMC
Map Great Britain v 562 App v 6.150 , GPS v 1.21 Boot 4.29, OS:1221
Privateer
PostPosted: Tue Oct 04, 2005 12:18 pm    Post subject: Reply with quote
Hi jimbokb,
Glad the information helped! Thumbs Up
Please don’t let the hassle beat you. Now you’ve got it all working you are so close to getting that custom menu that you want.
All you have to do is save a copy of your current tomtom.mnu in a very safe place, and decide which icon/function that you currently have on page one of your main menu that you which to swap with the Quick Cam Add on page 4. Then use MS Notepad to swap the two. Don’t forget to save your current tomtom.mnu first! ;)
Once you’re happy with the amended menu, you can start to really customise your menu settings and swap everything around! Thumbs Up
Robert.
Garmin Camper 770 LMT-D
jimbokb
PostPosted: Tue Oct 04, 2005 12:58 pm    Post subject: Reply with quote
Here is my current mnu file which bears little resemblance to what I am seeing on Tomtom.
Note I have added the command that you suggested. (your command highlighted)
MENUBLOCK|BLOCK_MAIN|BTM_GPS_POSITION|
MENUPAGE|TASK_PAGE1|Main Menu 1 of 4|
MENUITEM|TASK_NAVIGATE_TO|
MENUITEM|TASK_MENU_FIND_ALTERNATIVES|
MENUITEM|TASK_DELETE_ROUTE|
MENUITEM|TASK_SDK1|
MENUITEM|TASK_MENU_PREFERENCES|
MENUITEM|TASK_PAGE2|
MENUPAGE|TASK_PAGE2|Main Menu 2 of 4|
MENUITEM|TASK_MENU_PLAN_ATOB|
MENUITEM|TASK_SHOW_MAP|
MENUITEM|TASK_MENU_ROUTE_INSTRUCTIONS|
MENUITEM|TASK_ITINERARY|
MENUITEM|TASK_PAGE3|
MENUPAGE|TASK_PAGE3|Main Menu 3 of 4|
MENUITEM|TASK_SHOW_WEATHER|
MENUITEM|TASK_MENU_DOWNLOAD|
MENUITEM|TASK_MENU_TRAFFIC|
MENUITEM|TASK_TUTORIAL|
MENUITEM|TASK_SHOW_GPS_STATUS|
MENUITEM|TASK_PAGE4|
MENUPAGE|TASK_PAGE4|Main Menu 4 of 4|
MENUITEM|TASK_ADD_FAVORITE|
MENUITEM|TASK_DIAL_POI
Page 1 consists of.
Navigate To, Find Altern, Traffic, Add Fav, Change pref then arrow to nxt page.
Page 2
Advanced plan, Browse map, Clear Route, View route Itinerary arrow nxt page
Page 3
Weather, Download Xtras, Connect to phone, Guided tour (Which i could do without) , Configure Gps arrow to nxt page
page 4
Quick Add camera
No mater what I seem to change SDK 1 which I believe to be the camera will not swap places with ADD Favourite.
I know you say dont let it beat you but please its driving me nuts.
Privateer
PostPosted: Tue Oct 04, 2005 1:29 pm    Post subject: Reply with quote
Hi jimbokb,
Backup your current tomtom.mnu and try the following:
Code:
MENUITEM|TASK_SDK1|
MENUITEM|TASK_EMPTY|
MENUITEM|TASK_PAGE1|
Robert.
lyngarth
PostPosted: Fri Oct 07, 2005 6:05 pm    Post subject: Reply with quote
Where do you find the current tomtom.mnu. I have looked on my 700 and can't find it anywhere.
Lyngarth
PostPosted: Fri Oct 07, 2005 7:18 pm    Post subject: Reply with quote
Lyngarth, its not there unless you are adding stuff with the SDK (software development kit). You really have to go back over some of the posts called "New apps for your Go" and similar to follow what needs doing as it can get a bit complex
lyngarth
PostPosted: Fri Oct 07, 2005 7:39 pm    Post subject: Reply with quote
I see, thanks for that, will go and do some reading then
Lyngarth
PostPosted: Sat Oct 08, 2005 1:39 am    Post subject: Reply with quote
Sorry lingarth, didn't have time to find you a link earlier.....
the best descriptions I've found are More Apps for your Go
and More Goodies.... Custom Menus!
Hope this helps Smile
(Sorry pocketGPS guys, I know there are details here too, but they were "stickied" topics on the MyTomTomGo forum, so were easier to find!)
lyngarth
PostPosted: Sat Oct 08, 2005 1:23 pm    Post subject: Reply with quote
Many thanks for the links, will have a read and then give it a go later.
Lyngarth
lyngarth
PostPosted: Sat Oct 08, 2005 1:48 pm    Post subject: Reply with quote
Right then, I now have it all up and running, but while a was looking through the menus, iI pressed Add Camera, so now have a speed camera outside of my front door Embarassed can some one please tell me how to remove it, thats if you can remove it.
Lyngarth
PostPosted: Sat Oct 08, 2005 4:07 pm    Post subject: Reply with quote
Change preferences / manage POI / Delete POI / Select the POI category ( it will be My cameras or new cameras or similar)
Then select the POI, which I think will be at the top of the list because it sorts them in order of distance from your present location and then tap Yes to confirm the delete.
If you want to double check before you delete it, you can exit everything, go to Browse map / tap the arrow at top right or left of the screen (above the zoom bar) to centre the map on your house, then tap on the camera icon itself (you may need to zoom in and have a few gos to grab it) and a bpop up box should show the name of the camera. Remember that name and then go through the steps I started with above.
All the above assume you are at home when you do it! :D
jimbokb
PostPosted: Sun Oct 09, 2005 3:35 pm    Post subject: Reply with quote
I have tried the above MNU file which looks different to mine but once installed there is no change to Quick Cam Add which still remains on page 4 even though when you look at the mnu file SDK1 which i think is the Cam icon should be on page 1.
DeeSee
PostPosted: Mon Oct 10, 2005 6:34 pm    Post subject: Reply with quote
Hi Jimbokb,
Not sure why you are still having probs but I don't use phone so haven't tried to do what you are doing.
However, there was something mentioned a long time ago about the order of SDK entries (can't remember where or by whom).
Try this: Back up your existing mnu. Go to Catapps and remove all the entries. Put a TASK_EMPTY entry in place of the SDKs in your mnu. Save and reboot your TomTom.
Then go back to your mnu and Catapps and add SDK1 to your mnu in place of one of the TASK_EMPTY entries and the entry that you wish to correspond to for that into Catapps. Reboot your TomTom. Add SDK2 and second Catapp entry, if you have one.
Hope this helps.
By the way, to alter Prefs pages I think you use the following (again can't remember when or where I found this)
MENUITEM|TASK_SDK3|
MENUITEM|TASK_SDK5|
MENUITEM|TASK_PAGE1| ..........this is the end of the main menu. Add the following for Prefs menu and move tasks about to suit.
MENUBLOCK|BLOCK_PREF|BTM_GPS_POSITION|
MENUPAGE|TASK_PAGE5|Preferences 1 of 10|
MENUITEM|TASK_ABOUT|
MENUITEM|TASK_CHANGE_HOME_LOCATION|
MENUITEM|TASK_MAINTAIN_FAVORITES|
MENUITEM|TASK_SET_VOICE|
MENUITEM|TASK_SET_PROMPT|
MENUITEM|TASK_PAGE6|
MENUPAGE|TASK_PAGE6|Preferences 2 of 10|
MENUITEM|TASK_SET_STATUS|
MENUITEM|TASK_SET_VOLUME|
MENUITEM|TASK_SET_COLOR_SCHEMES|
MENUITEM|TASK_SET_BRIGHTNESS|
MENUITEM|TASK_SET_BACKLIGHT|
MENUITEM|TASK_PAGE7|
MENUPAGE|TASK_PAGE7|Preferences 3 of 10|
MENUITEM|TASK_SET_NAME_DISPLAY|
MENUITEM|TASK_SET_KEYBOARD_SIZE|
MENUITEM|TASK_SET_PLANTYPE|
MENUITEM|TASK_SET_TOLL|
MENUITEM|TASK_SET_COMPASS|
MENUITEM|TASK_PAGE8|
MENUPAGE|TASK_PAGE8|Preferences 4 of 10|
MENUITEM|TASK_SET_CRADLE|
MENUITEM|TASK_SET_DIST_UNITS|
MENUITEM|TASK_SET_CLOCK_TYPE|
MENUITEM|TASK_SET_LANGUAGE|
MENUITEM|TASK_PAGE9|
MENUPAGE|TASK_PAGE9|Preferences 5 of 10|
MENUITEM|TASK_SET_HIDEMAP|
MENUITEM|TASK_SWITCH_2D3D|
MENUITEM|TASK_LEFTHANDED|
MENUITEM|TASK_ROTATE_DISPLAY|
MENUITEM|TASK_PAGE10|
MENUPAGE|TASK_PAGE10|Preferences 6 of 10|
MENUITEM|TASK_CONFIGURE_POI|
MENUITEM|TASK_SWITCH_POI|
MENUITEM|TASK_DOWNLOAD_POI|
MENUITEM|TASK_MAINTAIN_POI|
MENUITEM|TASK_MANAGE_MAPS|
MENUITEM|TASK_PAGE11|
MENUPAGE|TASK_PAGE11|Preferences 7 of 10|
MENUITEM|TASK_DOWNLOAD_MAP|
MENUITEM|TASK_DOWNLOAD_SCHEME|
MENUITEM|TASK_DOWNLOAD_VERSION_NUMBER|
MENUITEM|TASK_DOWNLOAD_VOICE|
MENUITEM|TASK_PAGE12|
MENUPAGE|TASK_PAGE12|Preferences 8 of 10|
MENUITEM|TASK_SERVICE_LOGIN|
MENUITEM|TASK_TRAFFIC_ENABLE|
MENUITEM|TASK_PAGE13|
MENUPAGE|TASK_PAGE13|Preferences 9 of 10|
MENUITEM|TASK_TRAFFIC_SETTINGS|
MENUITEM|TASK_TRAFFIC_VIEW|
MENUITEM|TASK_TRAFFIC_REPLAN|
MENUITEM|TASK_TRAFFIC_UPDATE|
MENUITEM|TASK_PAGE14|
MENUPAGE|TASK_PAGE14|Preferences 10 of 10|
MENUITEM|TASK_SWITCH_BLUETOOTH|
MENUITEM|TASK_SWITCH_ASN|
MENUITEM|TASK_SWITCH_SOUND|
MENUITEM|TASK_SWITCH_TIPS|
MENUITEM|TASK_RESET_SETTINGS|
MENUITEM|TASK_PAGE5|
DeeSee
jimbokb
PostPosted: Mon Oct 10, 2005 7:27 pm    Post subject: Reply with quote
Have done all you suggest but to no avail.
I have to date 18 different MNU files and not one of them is the way I want it. I am still convinced that there is something else in the TT's own software that will not allow me to have things the way I want it.
It is also possible I am still not doing something right.
You would not believe how many people have tried to sort this one out, I get mnu files sent to me every few days by email some of them are so close its infuriating.
Still not to worry, I will not give up on this one anytime soon.
Thanks for your help thus far.
DeeSee
PostPosted: Mon Oct 10, 2005 8:14 pm    Post subject: Reply with quote
Another thought.
Since Quickam is back on page 4 it could be that your menu file is not being seen again.
Check that you have not inadvertently left a Carriage Return at the end of your menu. Your cursor should be at the end of the last line not on the line below when you look at it in notepad.
I also notice from your menu posting that you don't have the bar at the end of your last entry
MENUITEM|TASK_DIAL_POI .........here
Also the entry on the previous line MENUITEM|TASK_PAGE4| shouldn't be there but at the end and should be MENUITEM|TASK_PAGE1|
This might be infuriating but it is sortable - dig deep.
DeeSee
Page 2 of 4
22.063 (19 Jun 24)
