Minidish Regular Visitor
Joined: Sep 10, 2005 Posts: 84 Location: Manchester, UK
Posted: Tue Sep 27, 2005 10:40 pm Post subject: Interfacing with AutoRoute |
Has anyone tried the above? from what I understand I need a serial interface cable for the Streetpilot i3? problem is... I can't find one anywhere, I was thinking maybe making a cable up but I need a plug to fit the strange looking socket on unit, I have sourced a supply of replacement PC/USB cables which I guess I could attach a "y" joint with a serial plug... any ideas folks?
Paul |
zogman Frequent Visitor
Joined: Sep 05, 2005 Posts: 1417 Location: swindon uk
Posted: Wed Sep 28, 2005 9:15 am Post subject: |
why do you want to do this paul? |
Posted: Wed Sep 28, 2005 10:52 am Post subject: |
zogman wrote: | why do you want to do this paul? |
Good question zogman!
I noticed whilst using AutoRoute that it was possible to connect a suitable GPS so not wanting to be missing out on something I thought lets give it a go.
See below for snippet copied from AutoRoute help:
"You can configure the map to remain centred on your current location, to rotate to follow your travel direction, and to display a trail showing where you have traveled. In the GPS task pane to the left of the map, you can view the latitude and longitude coordinates of your current location and your altitude, the most recent time your GPS receiver recalculated your position, the speed at which you are traveling, your compass heading, and the strength of the satellite signal.".
I think reference to altitude will be for GPS units that measure altitude and then most of those I have seen use barometric measurement rather than satellite.
I also have other weather satellite software which allows input from a gps, so generally it would be nice to be able to interface through my serial port. |
Posted: Wed Sep 28, 2005 10:56 am Post subject: |
the i3 is just a basic plug n play gps without trackback for instance...if you want to do the stuff you mention have a look on the garmin site at the various gps specs,i'm sure something will suit.. |
Posted: Wed Sep 28, 2005 11:02 am Post subject: |
Having checks the specs on the i3 I would say it is compatable with AutoRoute if so then the way I interpret the info is that AutoRoute software does the track back etc not the i3. the i3 does conform to the NMEA specs required so I see no reason why it won't work? |
Posted: Wed Sep 28, 2005 11:11 am Post subject: |
would'nt a basic etrex do that.. |
Skippy Pocket GPS Verifier
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Wed Sep 28, 2005 2:17 pm Post subject: |
Minidish wrote: | I think reference to altitude will be for GPS units that measure altitude and then most of those I have seen use barometric measurement rather than satellite. |
The GPS doesn't need a barometer to measure the altitude, it can do it from the satelite fix. It's just not as accurate as the lat/long (about 1.5 times the position error).
In my experience it's pretty good though, checking the reported altitude at sea level or surveyed points (ie on mountains), the height is within 10-20 feet of reality. _________________ Gone fishing! |
Posted: Sat Oct 01, 2005 12:33 pm Post subject: Word from Garmin |
Thanks for your input zogman & skippy.
I have received a reply from Garmin sales support and it would appear I was wrong in assuming the i3 conforms to NMEA protocol, I was sure I read somewhere that it did.. oh well save me wasting time making a serial adapter cable, all is not lost I have the GPS bug good and proper now I just ordered a Etrex vista from ebay will be good for when I am up them there lakeland fells
I am still more than satisfied with my i3 I have created and added poi's for my favourite fishing waters...where will it stop next thing wil be a fish detector.
See Garmin's reply:
"Dear Paul,
Thank you for contacting Garmin
Please note that the i3 only connects to a PC via a USB Cable. AutoRoute
will need serial connection because it requires a different protocol called
NMEA to talk between the software on the Garmin GPS. Which I'm afraid that
the i3 does not support.
With Best Regards,
Ollie Stone
Sales Support Associate
Garmin (Europe) Ltd"
Cheers Paul |
