daveyonthemove Occasional Visitor
Posted: Wed Sep 28, 2005 1:09 pm Post subject: Any sat nav options for off ramblers? |
I currently have TTN5 on my ipaq hx4700, and have to admit it works a treat (unlike the tom tom support team).
What i will be needing shortly is a sat nave program designed for ramblers etc. I would like something that i can punch in co-ordinates (OS type) and it wil guide me on my way.
Is there any programs available like this? A map would also be handy, but a nessesity.
I should add that i'm not in a position to by a handheld device such as a garmin etc, so only looking for advice on software for the PPC.
Many thanks
Dave |
Joined: 30/12/2002 17:36:20 Posts: 4914 Location: Oxfordshire, England, UK
Posted: Wed Sep 28, 2005 1:13 pm Post subject: |
Hi daveyonthemove,
I use Memory-Map, but please look at our section on Topographical products that can be found here.
Garmin Camper 770 LMT-D |
Posted: Wed Sep 28, 2005 1:42 pm Post subject: |
Thanks very much for the quick and informative repply.
I will take a good look at the reveiws when i get a spare half hour.
Out of interest, how do you find the map source? I'm hoping to get some software by the weekend as i plan to go into the Scottish mountains, so plan to get the best software i can afford.
Dave |
Posted: Wed Sep 28, 2005 2:04 pm Post subject: |
Hi daveyonthemove,
The map source is spot on, as it is Ordnance Survey 2004 data. I have the full country Landranger (1:50,000 scale) maps.
I saw a number of products at the Ordnance Survey outdoor stand at the 2004 Royal Show. For my requirements Memory-Map was at the time (July 2004) the best package about. It’s now over a year later so things might have changed. Have a look at all of them.
As you walk, you need to look for 1:25,000 scale maps for which ever product you decide to buy.
nigelw Occasional Visitor
Posted: Thu Sep 29, 2005 12:36 am Post subject: |
When I was looking a few months back the 3 main options for OS based maps were Memory Map, Anquet and Fugawi. All 3 had downloadable demos, so you can try them out before you make a decision.
Doesn't the HX4700 have a VGA screen? MM now has full VGA resolution and supports rotation for portrait or landscape view. On a Axim X50v with VGA the OS maps are superb, but the screen isn't really bright enough outdoors in full sunshine. And battery life on a PDA with the screen at full brightness is poor, so you might want to get an extra battery unless you like short walks... |
Posted: Thu Sep 29, 2005 8:11 am Post subject: |
hi Nigelw,
Thanks for your input.
Yes the 4700 does use a VGA scren and it is very good, although i havent tried it in direct sunlight yet, so will watch out for that.
I wasn't aware that there was a demo available for memory map, and out of all the products in the above link, MM is the one i like the look of the most.
On the demo version can you pick the area you wish to use as a trial, or do you get what your given?
Got the power problem sorted with a battery back up pack, and a solar panel to atatch to my rucksack for those nice sunny days.
Dave |
oddsock Pocket GPS Verifier
Joined: May 01, 2004 Posts: 706 Location: Monmouthshire
Posted: Thu Sep 29, 2005 10:10 am Post subject: |
Uness your a fair weather walker you will need some means of keeping water off you ppc! I have a 2210 and two spots of rain on the screen and its off to the airing cupboard for a week to dry out before it can be used again ..Memory map had several areas in the country available for trial download .. the nearest area to me was near Swansea.. not all not sure about the others!
Dave |
Posted: Thu Sep 29, 2005 10:18 am Post subject: |
Thanks oddsock.
I'm happy to ramble off whatever the weather, although my PDA probably won't be as you pointed out. I will have to look out for a decent weatherproof cover this weekend before i go.
Any suggestions on where i can get a decent one, and what to look out for.
If i can find a demo of scotland (NE is where i'm off to) i will trial that while i'm up there, and buy the whole package on my return if it is as good as it looks.
Dave |
7andy Regular Visitor
Posted: Fri Sep 30, 2005 10:20 am Post subject: |
Aquapacs are good for 'waterproofing' your PDA. About 15 quid buys you the Standard, bit if you use a CF GPS then you'll probably need the Classic Plus for the extra height - about 20 quid.
Cheers, 7&Y |
LeighB Regular Visitor
Joined: Jan 23, 2005 Posts: 156 Location: Ipswich Suffolk UK
Posted: Fri Sep 30, 2005 1:42 pm Post subject: |
I use the Mio 168, with an external battery pack. This all fits nicely inside the larger Aquapac. I use the external antenna fitted on the top of my rucksack. Slightly fiddly, but it gives 1st rate satellite reception, whereas the built in antenna hanging down in front is more likely to lose its lock.
Software I use is Memory map OS 2004, if you get the 1:25000 maps for areas you intend to walk the detail is excellent. _________________ Leigh
Mio168 Kingston 256SD
TomTomNavigator3 3.07
TomTom Navigator 5
Memory Map 2004 OS 4.4
Checkpoint 2.02 |
Posted: Fri Sep 30, 2005 4:11 pm Post subject: |
Brilliant stuff. Thanks for your input guys.
I have got an aqua pack for mine now and it is good. i have faith that it will keep it nice and dry in a shower.
I have a bluetooth GPS receiver which is quite reliable, so i will seal it into a polythene bag and attatch it to my rucksack or hat for a good view of the skies.
Only problem is i have no time to order the software needed to get here for Saturday morning at latest, so it might all be in vain
Does anybody know of a high street store that might sell them. I know i will probably pay a bit extra, but it will be worth it in my opinion.
Thanks again for the info
Dave |
Posted: Fri Sep 30, 2005 5:36 pm Post subject: |
To use the Memory Map on the PDA combined with the GPS you need the full license so a downloaded demo probably won't work even if it is avail - the other thing you need to take into account is the size of the maps, they ain't small if you load up a big area so you will need an SD or CF card to put it all on, the 25,000 scale map areas do cover certain regions of Scotland (carngorms and the other main white winter sport area)
You can download the OS viewer from the memory map web site - get the 2004 version as the 05 doesnt work with the UK maps at the moment and give it a try (if you haven't yet) - Where abouts are you planning to go as I love Scotland - its great, the only downside is the long drive to get their. Mike |
Posted: Fri Sep 30, 2005 6:21 pm Post subject: |
Thanks for the advice Mike.
I have a 1gb cf card i use for movies and other app's i can remove and replace when needed,and a 512 sd card for my tomtom and speed camera alerts etc that are now permanantly on there.
I assume a 1gb card would be large enough to store most of the uk data?
Have downloaded the free trial, and i'm impressed with the detail, but dissapointed that it's only swansea. nevermind.
We are off to Garelochhead for accomadation and probably getting around alot of the surrounding area as we have 2 weeks up there.
Not been that far north myself, but was only saying last sunday how i would love to go for a long weekend one day. Imagine my surprise on monday when i get told i get to go for 2 weeks at work expense. lovelly
:D |
Posted: Fri Sep 30, 2005 7:21 pm Post subject: |
Check your MSN - or PM - mike |
Posted: Fri Sep 30, 2005 7:34 pm Post subject: |
Mike,
have just replyed on msn mail.
