![](modules/Forums/images/avatars/32928398450ec149ec6abd.gif)
Joined: 30/12/2002 17:36:20 Posts: 4914 Location: Oxfordshire, England, UK
Posted: Tue Sep 13, 2005 4:48 pm Post subject: |
I thought that it was about time that I experimented with custom menus on TomTom Navigator 5 for the PocketPC.
The first menu I created was identical to the default TomTom menu just as an experiment, so that I could get used to the structure of the coding. I used skuX’s excellent online menubuilder to create the menu. I used Notepad to change the headings.
There are a couple of things that I couldn't find. I wonder if anybody knows the identification name of the following tasks?
Call Number (default Main Menu 3 of 4)
CheckPOInt (which by default, installs into Main Menu 4 of 4)
Is there a definitive list (preferably with icon and the task identification name) that can be downloaded? Does anybody know if the SDK5 manual describes custom menus and if it does, whether the SDK5 manual can be downloaded (preferably in .PDF format)?
Garmin Camper 770 LMT-D |
Rabdo Regular Visitor
![](modules/Forums/images/avatars/207800911342ba676007aa8.gif)
Joined: Jul 26, 2004 Posts: 61 Location: Port Talbot, South Wales
Posted: Tue Sep 13, 2005 5:28 pm Post subject: |
Privateer wrote: | I thought that it was about time that I experimented with custom menus on TomTom Navigator 5 for the PocketPC.
Regards, |
For CheckPOInt, use menubuilder and insert the icon for 'Switch to POI-Warner' - it displays as checkpoint if you have it installed instead of poi-warner
rabdo |
BarMuda Occasional Visitor
Posted: Thu Sep 15, 2005 1:50 am Post subject: |
For the phone one edit the file in notepad and replace an item with
TASK_DIAL_POI
![Smile](modules/Forums/images/smiles/icon_smile.gif) _________________ Tom Tom One XL
Mazda MX5 1.8IS Second Edition |
![](modules/Forums/images/avatars/gallery/Sphere_animated_small_neg2.gif)
Posted: Sat Sep 17, 2005 3:16 pm Post subject: |
Ok I have just built my first menu using the online Skux systems (what a great bit of software that is), installed it (only got it working following this tread so many thanks to all) - Has anyone noticed the two arrows for navigation through the menus - both mine point to the Right but they do opperate in different directions? this is on the O2XDAIIs - Any thoughts - Mike |
BV Occasional Visitor
Posted: Sat Sep 17, 2005 3:36 pm Post subject: |
mikealder wrote: | Ok I have just built my first menu using the online Skux systems (what a great bit of software that is), installed it (only got it working following this tread so many thanks to all) - Has anyone noticed the two arrows for navigation through the menus - both mine point to the Right but they do opperate in different directions? this is on the O2XDAIIs - Any thoughts - Mike |
Mike, how did you get the "call number" icon on this skux menu?
BV |
Posted: Sat Sep 17, 2005 5:28 pm Post subject: |
I used the last avail item, which was save poi, when compiled up it gave me the phone option, but it doesn't work, so i am going try a text based edit along the lines set out on this thread - i am just confused why the page back arrow has the same appearance as forwards, i also put the arrows on the middle line but when i created the menu it over rides the bottom rh icon from that chosen to next page will get there in the end - great bit of software though - Mike |
Posted: Mon Sep 19, 2005 3:29 pm Post subject: |
Hi Rabdo and BarMuda,
Rabdo wrote: | For CheckPOInt, use menubuilder and insert the icon for 'Switch to POI-Warner' - it displays as checkpoint if you have it installed instead of poi-warner |
It tried that and got:
TASK_SDK1
Rabdo, I’m trying to use another third party application alongside CheckPOInt and unfortunately both third party applications use the same menu function name, which makes the menu building rather interesting! ;) I may have an experiment with the .CAP file to see if I can get the menu functions of both CheckPOInt and the other application to appear correctly in the menu. Thanks for the information though.
BarMuda wrote: | For the phone one edit the file in notepad and replace an item with
TASK_DIAL_POI |
BarMuda, many thanks, that works a treat!!!
Posted: Wed Sep 28, 2005 9:05 pm Post subject: |
I also have an XDA IIs. I have created my first SKUX menu, but even though I am dropping the notepad file into a created SDKRegistry folder I cannot get anything to happen. Any ideas Mike?
BV. |
Posted: Wed Sep 28, 2005 9:27 pm Post subject: |
Check the web site as to the specific instructions as to where the folder must reside - I have wiped my unit at the moment so I can't give you much more than this - I found the answer on the site and got it all working - if I have a play around over the weekend (which I more than likely will) I will let you know more - I do remember it needed to be the SDKregistry folder contained in another folder called tomtom, but I am not too sure if that was on the SD card or in the programs navigator folder in the main memory (I think it was the later)- Mike |
andy-c1 Lifetime Member
Joined: Feb 05, 2005 Posts: 1039 Location: East Sussex
Posted: Wed Sep 28, 2005 9:37 pm Post subject: |
awsome ,i have got it now .once you done it you realise how easy it is :D _________________ TomTom 5001 |
Posted: Thu Sep 29, 2005 5:06 pm Post subject: |
andy-c1 wrote: | awsome ,i have got it now .once you done it you realise how easy it is :D |
Andy, I am failing to get this application working, can you give me a clue, step by step.
Many thanks,
BV. |
Posted: Thu Sep 29, 2005 6:09 pm Post subject: |
all i did was use activesync opened
mobiledevice/my mobile/tomtom file ..
within tomtom make another file named SDKRegistry then within that file paste your file made from skux's website ,it worked a few times for me as i made a couple of trial runs _________________ TomTom 5001 |
Posted: Fri Sep 30, 2005 1:15 am Post subject: |
andy-c1 wrote: | all i did was use activesync opened
within tomtom make another file named SDKRegistry then within that file paste your file made from skux's website ,it worked a few times for me as i made a couple of trial runs |
Andy, Mike, Luz thanks for your input. The skux menu's have been mastered. If I can do it anyone can!
Such a lovely application.
All the best,
BV. |
MotoBorg Occasional Visitor
Joined: Jan 09, 2006 Posts: 13 Location: halesowen, West Midlands, UK
Posted: Mon Jan 09, 2006 4:40 pm Post subject: |
Several time before this question has been asked, but I can not see the answer.
Is there any way to change the entries on a sub menu, eg if you select "Navigate to..." there is the Navigate to sub menu with home, favourite, address etc.
Thanks for help |
lupos0_1 Lifetime Member
![](modules/Forums/images/avatars/210896915648709d6ed5619.jpg)
Posted: Mon Jan 09, 2006 6:37 pm Post subject: |
You can create a set of menus and sub menus (I think??) _________________ -------------------------------------------------------
Nokia N95
McGuider V7
Latest Maps
(Internal GPS) |
