Pocket GPS World :: View topic - TTN5 thru NAVMAN sleeve baud rate
argosafe
PostPosted: Wed Sep 28, 2005 7:58 pm    Post subject: TTN5 thru NAVMAN sleeve baud rate Reply with quote
I'm curently running TTN 5.1 thru a NAVMAN sleeve. What would be the correct BAUD rate?. I seem to think its 57800. Any advice? 8O
Tim Buxton
PostPosted: Wed Sep 28, 2005 8:05 pm    Post subject: Reply with quote
The default for the Navman sleeve is 57600 but if it's running at any speed, go with the flow.
Tim
argosafe
PostPosted: Wed Sep 28, 2005 9:01 pm    Post subject: Reply with quote
Thanks Tim, I get the feeling that a BT GPS reciever is probably what I should now be looking for! Embarassed
Tim Buxton
PostPosted: Wed Sep 28, 2005 10:41 pm    Post subject: Reply with quote
Third party BT receivers coupled with TTN5 also have their problems, but I've had my Navman SE sleeve and two non-TomTom BT receivers working with it, so it can be done, and if I can do it, it isn't rocket science.
Tim
trevor.dowle
PostPosted: Fri Sep 30, 2005 7:46 pm    Post subject: Re: TTN5 thru NAVMAN sleeve baud rate Reply with quote
I'm running mine at 9600, as the 57800 option isn't there! On the final screen for configuring the GPS device the NAVMAN option needs to be selected, and I think this must over-ride the BAUD rate settings.
Regards
Trev D.
argosafe
PostPosted: Fri Sep 30, 2005 9:03 pm    Post subject: Reply with quote
Thanks Trev. I've left mine at 57600. the Time to first fix is between 5 and 8 minutes, hows yours?
Also, what IS Baud rate!?
trevor.dowle
PostPosted: Sat Oct 01, 2005 12:14 pm    Post subject: Reply with quote
Baud rate is a value given to communication devices such as modems to describe the amount of data they can carry per second. The higher the Baud rate the more data the device can transmit per second, typically in a binary channel the baud rate is equal to the bit rate, therefore 1 baud = 1 bit a second.
regards
Trev D.
