Pocket GPS World :: View topic - MIO 168 Battery Replacement
carcuscrae
PostPosted: Tue Sep 27, 2005 7:14 pm    Post subject: MIO 168 Battery Replacement Reply with quote
I think the battery on my MIO 168 is dying as it hardly lasts anytime at all now. Is it possible to replace the battery or do I have to replace the whole unit?
Pocketgps
PostPosted: Tue Sep 27, 2005 8:20 pm    Post subject: Reply with quote
Try these web sites
Here
And Here
neil01
PostPosted: Wed Sep 28, 2005 12:29 pm    Post subject: Reply with quote
This question seems to be asked a few times, and the information is not that easy to find. Especially since the official response seems to be that the battery is not replacable and the unit should be replaced when it expires.
Would this be a suitable post to be made 'sticky'?
LiveLifeGoJump
PostPosted: Wed Sep 28, 2005 11:29 pm    Post subject: Reply with quote
The Mio-tech site is easy to find & one of the FAQ is aboult battery replacement.
Question & Mio response
» Mio168
Can I replace a dead battery by myself?
Last update: 2004-10-14 14:28
Batteries can only be replaced by returning your device to your dealer. Any attempt to replace the battery yourself will result in a loss of all waranty.
Check it out yourself at
http://www.mio-tech.be/support/faqs/index.php?sid=19995&lang=en&action=artikel&cat=3&id=23&artlang=en
Mio 168 FAQ page is at http://www.mio-tech.be/support/faqs/index.php?action=show&cat=3
Cover many more Mio units as well.
If riding in a plane is flying then riding in a boat is swimming. If you want to experience the feeling
GET OUT OF THE VEHICLE
lamplight
PostPosted: Thu Sep 29, 2005 4:36 pm    Post subject: Reply with quote
Given the warranty issues (which I guess will soon not apply to my Mio 168, given it's age), I'm interested to know if anyone has experience of replacing a battery for themself. And if so, how complex a procedure was it?
Always good to be prepared. Smile
Sequin
PostPosted: Sun Oct 02, 2005 10:38 am    Post subject: Reply with quote
I've just had mine open to see if I could fix a problem with the joystick (I couldn't) but it looks like a battery replacement would be an easy enough job.
Backup your system first - removing the battery will cause a hard reset, wiping everything off.
Remove the four screws in the corners of the back (no need to take out the one on the antenna hinge) then gently prise apart the case at the bottom using your fingernails- the back will come away and you will see the battery in the middle of the innards - it is stuck down, so you will need to free it (I think it is held down with one of those sticky pads) then disconnect it from the circuit board. Connect the new one and re-assemble, making sure you connect the antenna lead to the circuit board before you put it back together, as it pops off when you remove the back - it's a bit fiddly, but easy enough.
Click the case back together and replace the screws. Charge up the new battery and you should be good to go.
Don't forget that this will invalidate your warranty
lamplight
PostPosted: Mon Oct 03, 2005 12:13 am    Post subject: Reply with quote
Sequin that's a really useful piece of information. Thanks. Hope I never have to use it, but I for one will keep it handy just in case.
ps73uk
PostPosted: Tue Oct 04, 2005 9:47 am    Post subject: Reply with quote
Shame you cant yet get the battery in the UK though (not that i can find anyway?), it's $52 to ship it from america!
Garmin Streetpilot i3,
Tomtom One
Paul
ps73uk
PostPosted: Tue Oct 04, 2005 9:56 am    Post subject: Reply with quote
Does this help anyone Wink
http://www.gpsforless.co.uk/product_details.php?id=1390
Tomtom One
Paul
LeighB
PostPosted: Wed Oct 05, 2005 11:34 am    Post subject: Reply with quote
As a matter of interest do we know what the capacity of the standard Mio 168 battery is?
The replacement on that link is 1300 mah, and it seems to suggest that this is a higher capacity.
Anyone know?
Leigh
Mio168 Kingston 256SD
TomTomNavigator3 3.07
TomTom Navigator 5
Memory Map 2004 OS 4.4
Checkpoint 2.02
LiveLifeGoJump
PostPosted: Wed Oct 05, 2005 12:57 pm    Post subject: Reply with quote
According to the spec. listed at http://www.globalpositioningsystems.co.uk/mio-168-pocket-pc-including-car-kit-specification.html
it is 900Mah. so the replacement is approx. 44% higher capacity.
Sounds good if you are out of guarantee.
LeighB
PostPosted: Wed Oct 05, 2005 1:14 pm    Post subject: Reply with quote
Thanks,
It does sound well worth while when the original fails.
What experience have owners of the Mio of initial battery life?
Is it a couple of years, or maybe less?
Leigh
TomTom Navigator 5
Checkpoint 2.02
Pocketgps
PostPosted: Wed Oct 05, 2005 5:46 pm    Post subject: Reply with quote
The standard battery size IS 1350mAH period.
Sequin
PostPosted: Wed Oct 05, 2005 8:21 pm    Post subject: Reply with quote
it is 900Mah.
It says 1350mAh on mine!
LeighB
PostPosted: Wed Jun 28, 2006 12:51 am    Post subject: Reply with quote
Sequin,
You posted helpful instructions here about how to replace the battery.
I have followed these, and all seemed to work well, but I no longer have a GPS signal.
I opened the case again twice to check that I had connected the antenna lead, and I am sure that it is securely fixed, is there anything else I may have forgotten?
Hope you can advise?
Leigh
TomTom Navigator 5
Checkpoint 2.02
