Pocket GPS World :: View topic - C340 Need longer battery life? External power
crystaljukebox
PostPosted: Tue Sep 27, 2005 2:30 am    Post subject: C340 Need longer battery life? External power Reply with quote
I'm a UPS driver and I'm interested in getting a Nav unit. I was looking at the C340 and the TomTomGo 700. I think I narrowed it down to the c340. Now my problem is that the battery ONLY lasts 4-5 hrs. I'll need around 10 hrs a day. We have no cigarette lighter plugs, and I jump from truck to truck so hard wiring is not an option.
Is there some type of external power source that I can put in my back pack and use when needed? A rechargeable power supply that I plug the cigarette lighter adapter in and then plug into the Nav unit???
Some type of unit like you would you laptop in but with a cigarette adapter????
Thanks in advance?
I need a Nav unit with Touchscreen, mininum buttons to push just to enter in an address. Nothing to fancy if you know of any more units with 12+ hrs of battery life. I have searched all over the net and ebay.
THe C340 also had better map coverage than the tom700.....
crystaljukebox
PostPosted: Tue Sep 27, 2005 4:15 pm    Post subject: Solution.... Reply with quote
The unit uses.....
Power Input: 12/24 Vdc
Usage: 15w max. @ 13.8 Vdc
Battery Life: up to 8 hours
http://store.yahoo.com/yhst-3455591325931/mm-9.html
IF the unit only uses 10w, then this battery pack will last 9 hrs, with cigarette output.
This will work for me......
Thanks for anyone that tried to help me.
I'm going to order both of these units later today!
PostPosted: Tue Sep 27, 2005 5:01 pm    Post subject: Reply with quote
Where are you based, UK or US?
Donald
PostPosted: Tue Sep 27, 2005 5:44 pm    Post subject: Re: Solution.... Reply with quote
crystaljukebox wrote:
The unit uses.....
as a 'portable' gps system that I can use in friends cars or on coach outings etc, I use an ordinary rechargable sealed lead acid gell battery in a bum bag.(fannypack)
I have a nominal 12V at 2.2Ah that powers my PDA_Amplified GPS unit for several hours... I would say that a sealed lead acid battery of 7Ah may be the bees knees...
In my case, I use a ciggy lighter socket on the battery. For your application, you could use a much smaller polarised plug & socket...
Axim X50 & TT5, Arkon CM820 powered mount with built in sirf2 gps
Axim 5 sans GPS Rx
Ford Focus 2L Ghia, Wife, kids, dog, cats, mortgage, bank manager & taxman to support, debts, windows need painting - (I cut the grass! - its rained - it needs
Donald
PostPosted: Tue Sep 27, 2005 5:48 pm    Post subject: Re: Solution.... Reply with quote
The unit uses.....
I Hasten to add that the powered GPS mount converts the 12v (Nominal) to 5V that is required by the PDA - If you consider a PDA route, then you must never wire the PDA direct to 12v (Unless up want to send smoke signals instead!) Wink
Axim 5 sans GPS Rx
