Pocket GPS World :: View topic - Checkpoint or POI-Warner for TT5.1
Tricky2005
PostPosted: Fri Aug 05, 2005 11:44 pm    Post subject: Checkpoint or POI-Warner for TT5.1 Reply with quote
The title says it all, any opinions, comments etc would be appreciated.
DriveBy
PostPosted: Thu Sep 15, 2005 9:59 am    Post subject: Reply with quote
Why not use both?
Then when you forget to start Checkpoint (as I do) you still get speed camera warnings.
It then reduces the chances of the overlay missing a camera, neither one picks them all up individually, but collectively they do miss fewer.
Just set the audio warnings so that they don't both "talk" at the same time.
Pocketgps
PostPosted: Thu Sep 15, 2005 2:11 pm    Post subject: Reply with quote
I use CheckPOInt with TT5 and find it works OK, DriveBy says that they miss some on occasions, I find that this is usually due to the way you have the Detection Angle set, if to narrow then when a camera is around a bend it sometimes misses it, set to wide and you pick up others on near roads !
POI-Warner worked ok with NAVIGON 4.2 but misses a lot with NAVIGON 5.1, but have not used it with TT5.
DriveBy
PostPosted: Thu Sep 15, 2005 5:42 pm    Post subject: Reply with quote
I do have my Checkpoint set on a fairly wide angle.
To be fair - it does not miss lloads of camera's - but then it only needs to miss one.........to cause a problem.
I prefer the belt and braces approach to be sure.
Of course, the real answer is not to ever exceed a speed limit Wink
spook51
PostPosted: Fri Sep 16, 2005 9:56 am    Post subject: Reply with quote
Has anyone found a way to cure the Checkpoint flickering display? I find it so irritating that I don't use Checkpoint.
DriveBy
PostPosted: Fri Sep 16, 2005 7:11 pm    Post subject: Reply with quote
The only answer seems to be to turn off the visuals in checkpoint and just rely on the audio warnings.
The advantage of using those is that they are time adjustable, so can be set to warn before the TTN or pocketgps camera settings come into effect as an extra warning.
I have checkpoint on audio only and pocketgps on both audio and visual on my TTN5.1 and it seems to work OK.
TTN5.1 does seem to have an annoying habit of "forgetting" the audio warnings though..........
spook51
PostPosted: Sun Sep 18, 2005 7:56 am    Post subject: Reply with quote
I don't think that a time adjustable warning is such an advantage - if you slow down after the time warning it isn't accurate whereas a distance warning is.
I can't say I've noticed TT5.1 forgetting to 'blast off' but I'll check when I'm out and about.
Hoppy
PostPosted: Sun Sep 18, 2005 12:54 pm    Post subject: Reply with quote
I disagree if I'm doing 60mph and the warning given is 30 secs to speed camera, then I slow down because of traffic or whatever and I'm only doing 40mph then checkpoint generaly warns me again 30 secs to go which is correct I've always found this accurate if the speed camera is in the correct place, which also aplies to the distance warning.
spook51
PostPosted: Sun Sep 18, 2005 3:49 pm    Post subject: Reply with quote
Each to his/her own I guess. I prefer anything spoken to be a navigation instruction so I've set up one warning (an alarm sound) a preset distance before each camera. When that sounds I'm sufficiently alerted
To be perfectly honest, having not used Checkpoint because of the flickering, I now find I didn't need it anyway.
22.071 (03 Jul 24)
