smitty03 Occasional Visitor
Posted: Sun Sep 18, 2005 10:46 am Post subject: |
Mine worked when I was coonecting the TTG via usb and the new card was via a usb card reader-I wonder if it is involving the HDD which is somehow making the difference?
Try different ways of copying e.g. whole TTG file and copy/paste into HDD then to new card and if that doesn't work individual files etc. |
rkm_hm Frequent Visitor
![](modules/Forums/images/avatars/gallery/web.jpg)
Joined: Nov 28, 2004 Posts: 532 Location: Warwick, UK
Posted: Sun Sep 18, 2005 10:59 am Post subject: |
motordoctor wrote: | 125,646,848 bytes on tom tom card but only 125,479,845 bytes copied onto new on and same onto pc hard drive, it seems to be missing some files somewhere ![Question](modules/Forums/images/smiles/icon_question.gif) |
Have you tried doing a file by file reconciliation between old and new? [There are not that many files to check].
If any are missing from the new set, copy them over individually. _________________ Roger
TomTom via135
Satmap Active 10+ v1.50 with full UK 1:50k map and 1:25k/1:10k County maps of Hampshire & Warwickshire |
rescueme Occasional Visitor
Posted: Tue Dec 20, 2005 9:15 pm Post subject: |
I am trying to copy my 128 card over to my 512 Scandisk card.
Eventhough I have selected show hidden files in control panel (WinXP) and have used a card reader to tranfer straight from TTOne, I still can't get all the files to copy.
Any help please?!? |
Posted: Tue Dec 20, 2005 9:39 pm Post subject: |
rescueme wrote: | I am trying to copy my 128 card over to my 512 Scandisk card.
Can you be a bit more exlicit about what actually happens?
It sounds as if you have the old card in TT1 and the new one in a card reader both connected to the computer at the same time, so you are trying to copy directly from one to the other without using your hard disk. Is that correct?
When you think the copy has finished, leave it a few more minutes for all buffers to empty. Then use Windows Explorer to look at the properties of both cards. They should both report exactly the same number of files and folders and pretty much the same amount of space used.
If they don't compare properly, what are the differences? _________________ Roger
TomTom via135
Posted: Tue Dec 20, 2005 10:51 pm Post subject: |
Roger,
You are absolutely correct, I have checked the properties and the dirfference is minimal, 122,257,408 for new card and 122,275,840 for the old one.
However I re formatted the card as FAT to match the TT card, instead of FAT32 and although the difference between the two reduces the TT rejects the card straight off without uploading from it first!
Gareth |
