dan6540 Occasional Visitor
Posted: Sat Sep 17, 2005 1:23 pm Post subject: tom tom 5 on acer n35 |
Can anyone help me with what the gps setting should be for this handheld as i cannot get the tom tom software to locate any sattelites, it says no valid gps signal. Any help would be very much appreciated |
sengadog Occasional Visitor
Posted: Sat Sep 17, 2005 10:33 pm Post subject: |
Settings are OTHER CABLE DEVICE, then baud rate of 57600 then GPS ON NAVIGATOR. I have found on mine that sometimes I then have to do a soft reset then enter tomtom again to make it search for the satellites. You will see a little circle in the top right hand side of the screen, this will start to rotate if u have the correct settings. Be aware that it can take minutes for it to lock onto satellites. I have purchased an external aerial for mine from ebay and its much better at finding and keeping a lock onto satellites whislt driving. |
Pc-Mobile Frequent Visitor
![](http://www.pocketgpsworld.com/blank.gif)
Joined: 26/10/2002 10:38:36 Posts: 789 Location: Hong Kong
Posted: Sun Sep 18, 2005 6:23 am Post subject: |
You also have to configure the correct com port that the internal GPS use.
I do not have a n35 so do not know what it is. On Mio168 clone it is com 2. _________________ Pc-Mobile
http://pc-mobile.net/gps.htm |
Posted: Sun Sep 18, 2005 3:41 pm Post subject: |
thanx for the help! |
joshua197 Occasional Visitor
Posted: Tue Sep 20, 2005 12:00 am Post subject: |
According to N35 manual, GPS settings are:
Other Cable Device, 9600bps on COM8:
I have tried sengadog's settings and they work. However, need to soft reset every time N35 is turned on. Don't know whether settings have anything to do with this. |
