Hoppy Regular Visitor
lupos0_1 Lifetime Member
Posted: Wed Sep 14, 2005 5:36 pm Post subject: |
I tried it and works for me
andy-c1 Lifetime Member
Joined: Feb 05, 2005 Posts: 1039 Location: East Sussex
Posted: Wed Sep 14, 2005 7:44 pm Post subject: |
yeah i tried it as well couldn't get it to work
couldn't some1 make a how to for dummies please step by step guide _________________ TomTom 5001 |
wazzzzupmate Regular Visitor
Posted: Wed Sep 14, 2005 10:33 pm Post subject: |
ok, skux's is a good utility, unless you want to use landscape mode.
The screen rotate only allows you to rotate the screen through 180 degrees. Fine if you need to hold your pda upside down!!
Think I read somewhere that this is being looked into.
Keep up the good work. |
lbendlin Pocket GPS Staff
Posted: Wed Sep 14, 2005 10:45 pm Post subject: |
Actually, this is a non-issue as long as you don't chance the preferences menu. The standard preferences menu has the "rotate screen" feature and it works properly. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Wed Sep 14, 2005 10:48 pm Post subject: |
Cheers, I must have changed the prefs menu. ooops |
julianbarker Lifetime Member
Posted: Wed Sep 14, 2005 10:49 pm Post subject: |
I have explained this in the other thread - use the normal menus to switch to landscape.
Any menu you create using the utility will display in Landscape.
Use File Explorer to alter the name of the menu file if you ever need the default menus to switch back and forwards to landscape. The nrename the file back. Simply adding and deleting a character will switch between default and customised menus. |
Posted: Thu Sep 15, 2005 6:42 pm Post subject: |
like i said i am a dummy when it comes to making this sort of stuff ,although i do want to learn how
with skux's setup ..how do you get the ie "travel to" all the other option within it _________________ TomTom 5001 |
BV Occasional Visitor
Posted: Thu Sep 15, 2005 7:19 pm Post subject: |
lbendlin wrote: | Actually, this is a non-issue as long as you don't chance the preferences menu. The standard preferences menu has the "rotate screen" feature and it works properly. |
Lutz,
there is not the "call number" function in the skux menu builder and I do not know how to contact that site. Do you have any influence with them to add the "call number" feature?
Many thanks, BV |
Posted: Thu Sep 15, 2005 11:27 pm Post subject: |
Or, as I mentioned above, to revert to the original menus, just rename the file. Nme it back and you get your custom menues back. |
