Pocket GPS World :: View topic - Saved/Recent File 'hack' (95900)
Waffty
PostPosted: Thu Sep 15, 2005 5:34 pm    Post subject: Saved/Recent File 'hack' (95900) Reply with quote
I was wondering if there was a way to hard code either the Recent or Saved text files, for those hard to find addresses/locations.
To expand on this, if I use something like multimap to find a location, is there anyway to use the grid reference it supplies, to hard code an entry into one of the above text files? As on a few occations, my 95900 hasn't picked up an address, that I've been able to find using Multimap.
Many thanks in advance.
Waffty.
Waffty
PostPosted: Wed Oct 12, 2005 4:33 pm    Post subject: Reply with quote
Ok, looks like I've answered my own question.
If you find the 'Recent.txt' file in your "My Flash Disk" directory, make a copy of it for safe keeping.
Copy it over to your PC using active sync. Edit it with a suitable editor (notepad). In there you'll see your last entry in the following format.
EMC|-|48|-|M3 3|Manchester|M22 4|Enterprise Point|-|-|-|-2.26122|53.39765|-|-|
Make a copy of this using cut & paste & edit out all the info except the longtitude & latitude numbers and the name, making sure to replace the data with a "-" character
EMC|-|-|-|-|-|-|-|-|-|-|-2.26122|53.39765|-|-|
Open your browser and do a post code search on http://www.multimap.com . At the bottom the Multimap page, you'll see the longtitude & latitude for your search. Make a note of these or simply cut & paste their values directly into your entry above & simply replace the first part (in my case EMC) with the correct name.
Home|-|-|-|-|-|-|-|-|-|-|-0.12665|51.50325|-|-|
Now, from my limited knowledge, you'll need to add an extra number to both the longtitude & latitude figures as Multimap uses 4 numbers after the decimal point & Medion uses 5. I've got round this by simply adding the number 5 on to the end of the number given out of Multimap, which appears to work ok.
Then simply copy the file back to the same location (using activesync). Perform a reset & with a bit of luck, you'll see your new entry under the 'recent' setting.
I'm guessing you could also do this on a journey by doing the same on the journey tab.
I've not done too much testing on this, so please only attempt this, if you've got a full backup of your data, as I'd hate for you to loose anything important.
Happy 'Nav'ing'
Waffty.
Hooloovoo
PostPosted: Mon Oct 31, 2005 6:25 pm    Post subject: Reply with quote
That's correct. I've been doing this for ages to enter Geocaching coordinates into my PNA200S.
Although I haven't found any problem with the number of decimal places on coordinates. I just enter whatever I have, and it works. I also did this on a recent holiday to Scotland, where most of the B&Bs I was staying in didn't have house numbers or anything. So I just put the full postcode into multiman as you said, then entered the coordinates it gave me.
One thing you may not have noticed is that whatever coordinates you enter, it will shift those coordinates to be on the road nearest the point you entered. This is a pain for geocaching when I'm trying to enter a point that may well be miles away from a road in the middle of nowhere. However, there is a way around this!
To use you example..... if you enter just this in your favourites.txt file:
If you then edit the file, and re-save the location, when you edit the file you will find it has changed it to this:
EMC|-|48|-|M3 3|Manchester|-|-|-|-|-|-2.?????|53.?????|-|-|
Where the ????? are the points on the nearest road. But if you enter this:
EMC|-|-|-|-|Manchester|-|-|-|-|-|-2.26122|53.39765|-|-|
Then it won't adjust the coordinates. Somehow it needs the "Manchester" entry to workout which part of the map to load.
But you probably didn't need or want to know all that! Laughing
You can also do the same with route.rte files in your /route directory, if you want to batch-enter loads of coordinates all in one go on your PC.
Simple eh!! Could they make it any more awkward? I guess we should be grateful that they use ascii files so editing them is easy..... it could be in some weird binary format.
Now if I could only work out how the binary POI files work, there would be no need for POI warner...........
Hooloovoo
PostPosted: Mon Oct 31, 2005 6:28 pm    Post subject: Reply with quote
Oh and I've also found out that you don't need to perform a reset to get it to read the files that you have edited. You only need to exit the navigation application and re-start it. This is handy for me because whenever I do a reset the screen calibration is always out. So the less I have to reset the better.
I've also done the OS hack, and installed a version of windows notepad on my PNA200S to allow me to edit the files on the move without needing access to a PC, which again is great for entering geocaching coordinates whilst out in the field doing a multi-cache!
Hooloovoo
PostPosted: Mon Oct 31, 2005 6:29 pm    Post subject: Reply with quote
Unfortunately I've not found any way to directly enter coordinates via Navigator. If you know of a way.... please tell me! Laughing
22.062 (12 Jun 24)
