Pocket GPS World :: View topic - This util should be made a STICKY
Hoppy
PostPosted: Tue Sep 13, 2005 11:20 pm    Post subject: Reply with quote
Have you not read this then about 10 posts down http://pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=22522
lupos0_1
PostPosted: Wed Sep 14, 2005 5:36 pm    Post subject: Reply with quote
I tried it and works for me
Laughing
andy-c1
PostPosted: Wed Sep 14, 2005 7:44 pm    Post subject: Reply with quote
yeah i tried it as well couldn't get it to work
couldn't some1 make a how to for dummies Wink please step by step guide
TomTom 5001
wazzzzupmate
PostPosted: Wed Sep 14, 2005 10:33 pm    Post subject: Reply with quote
ok, skux's is a good utility, unless you want to use landscape mode.
The screen rotate only allows you to rotate the screen through 180 degrees. Fine if you need to hold your pda upside down!!
Think I read somewhere that this is being looked into.
Keep up the good work.
PostPosted: Wed Sep 14, 2005 10:45 pm    Post subject: Reply with quote
Actually, this is a non-issue as long as you don't chance the preferences menu. The standard preferences menu has the "rotate screen" feature and it works properly.
wazzzzupmate
PostPosted: Wed Sep 14, 2005 10:48 pm    Post subject: Reply with quote
Cheers, I must have changed the prefs menu. ooops
julianbarker
PostPosted: Wed Sep 14, 2005 10:49 pm    Post subject: Reply with quote
I have explained this in the other thread - use the normal menus to switch to landscape.
Any menu you create using the utility will display in Landscape.
Use File Explorer to alter the name of the menu file if you ever need the default menus to switch back and forwards to landscape. The nrename the file back. Simply adding and deleting a character will switch between default and customised menus.
andy-c1
PostPosted: Thu Sep 15, 2005 6:42 pm    Post subject: Reply with quote
like i said i am a dummy when it comes to making this sort of stuff ,although i do want to learn how
with skux's setup ..how do you get the ie "travel to" all the other option within it
TomTom 5001
BV
PostPosted: Thu Sep 15, 2005 7:19 pm    Post subject: Reply with quote
Lutz,
there is not the "call number" function in the skux menu builder and I do not know how to contact that site. Do you have any influence with them to add the "call number" feature?
Many thanks, BV
julianbarker
PostPosted: Thu Sep 15, 2005 11:27 pm    Post subject: Reply with quote
Or, as I mentioned above, to revert to the original menus, just rename the file. Nme it back and you get your custom menues back.
