Pocket GPS World :: View topic - BM6300 POI's
BM6300 POI's
Trauma999
PostPosted: Mon Sep 12, 2005 7:47 pm    Post subject: BM6300 POI's Reply with quote
Im a new boy to the GPS world and have just recently purchased a blue media 6300. Im having problems converting POI files which are arent DAT files into DAT files to download and install. Any advice would be grateful
MikeyF
PostPosted: Tue Sep 13, 2005 6:17 pm    Post subject: POI's Reply with quote
Trauma,
If I read your message correct your trying to convert a file to a dat file.
Can you tell me what format the orignal file is?? then I maybe able to help.
Mikey
Trauma999
PostPosted: Tue Sep 13, 2005 11:46 pm    Post subject: BM6300 POI Reply with quote
The files are in OV2 format. Ive also had a play around with some CSV files as well.
MikeyF
PostPosted: Wed Sep 14, 2005 4:33 pm    Post subject: POI files Reply with quote
CSV files can be converted using the destinator console on the pc.
You can also use POIedit which is a piece of software for converting files, I don't use it so I can't comment.
It can be downloaded from :- www.poiedit.com/index.htm
If there is a problem locating what you want in the correct format, I'd say find another site there are loads about.
Eg. www.poihandler.com who support destinator, and are worth registering with, I have.
Hope this helps
Mikey
Trauma999
PostPosted: Wed Sep 14, 2005 11:49 pm    Post subject: Bm6300 POI Reply with quote
Thanks managed to download and install some new POIs onto my console. The next problem is that they are saved into the favourites section but I want them in with the other POIs so I can search for individual items. Can you add new categories for eg McDonalds?
Any ideas?
MikeyF
PostPosted: Sat Sep 17, 2005 7:59 pm    Post subject: POI's Reply with quote
Once you have the DAT file, simply copy into the following directory on your PPC:-
DestinatorApps\Destinator\Common\Favorites
Once the file is there, you simply run destinator and goto destinate - favorites and the POI will be there under it's own title.
Mikey
