Pocket GPS World :: View topic - Rikaline 6010 Flashing but no position data
Gruff
PostPosted: Sat Sep 10, 2005 3:52 pm    Post subject: Rikaline 6010 Flashing but no position data Reply with quote
I have two Rikaline 6010 Gps receivers which have
worked great for the last 2 years.
Now one of them when first switched on starts flashing
straight away, I seem to receive data from the serial port but
the receiver sends no position data.
Here is the data I get back from the device, can anyone please
advise me as to what has gone wrong and what I can do to get it
working again.
Version 220.006.000ES-05411
$TOW: 0
$WK: 1151
$POS: 6378137 0 0
$CLK: 96389
$CHNL:12
$Baud rate: 4800 System clock: 12.277MHz
$HW Type: S2AR
$GPGGA,235948.000,0000.0000,N,00000.0000,E,0,00,50.0,0.0,M,,,,0000*3A
$GPRMC,2$GPGGA,235948.000,0000.0000,N,00000.0000,E,0,00,50.0,0.0,M,,,,0000*3A
$GPRMC,235948.000,V,0000.0000,N,00000.0000,E,0.00,,260102,,*0C
$GPVTG,,T,,M,0.00,N,0.0,K*7E
$GPGGù$Version 220.006.000ES-05411
$TOW: 0
$WK: 1151
$POS: 6378137 0 0
$CLK: 96389
$CHNL:12
$HW Type: S2AR
$TOW: 0
$WK: 1151
$POS: 6378137 0 0
$CLK: 96389
$CHNL:12
$HW Type: S2AR
$TOW: 0
$WK: 1151
$POS: 6378137 0 0
$CLK: 96389
$CHNL:12
$HW Type: S2AR
$TOW: 0
$WK: 1151
$POS: 6378137 0 0
$CLK: 96389
$CHNL:12
$HW Type: S2AR
$TOW: 0
$WK: 1151
$POS: 6378137 0 0
$CLK: 96389
$CHNL:12
$HW Type: S2AR
$GPGGù
This sequence seems to keep repeating Sad
Any help would be grateful
f948lan
PostPosted: Sat Sep 10, 2005 10:04 pm    Post subject: Reply with quote
Sounds like the internal bettery issue to me. See my previous thread
here for more details and a solution.
Gruff
PostPosted: Sun Sep 11, 2005 12:08 am    Post subject: Reply with quote
Thanks for a quick responce f948lan,
I had seen your thread and thought that
as I was getting data from the gps receiver
that it would not be the same fault.
Anyway I took the bull by the horns and opened
it up as you described, found the battery, got my
multimeter out and measured the volts in the battery.
It said that I had 3.1 Volts.
Damn, it seems ok.
Sod it I thought its coming out. Found my soldering iron
and my magnifying glass (my eye sight aint what it used to be)
and unsoldered the battery.
To my amazement after plugging it in it worked. Smile
As you said it works great without the battery but takes a bit longer
to lock on to the sat,s.
Many thanks again for the advice.
Ps Have you put your case back on and what did you use to seal it.
22.063 (19 Jun 24)
