DPL Regular Visitor
Posted: Fri Sep 02, 2005 7:25 am Post subject: |
I've missed a trick here (which is not unusual) If I follow your link for v3.084 above the website talks only about v 3.074.2 and when I download it remains at 3.074.2 as I've already got.  _________________ Garmin C320 & Garmin Quest |
Skippy Pocket GPS Verifier
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Fri Sep 02, 2005 10:39 am Post subject: |
Just tried it now and I got 3.084.1 so it works OK for me.
Try going to the website then pressing control (or maybe shift) then the reload button on your browser. You might be getting an old cached version of the web page.
I'll followup to the forum, maybe other people have some ideas.  _________________ Gone fishing! |
DPL Regular Visitor
Posted: Fri Sep 02, 2005 12:01 pm Post subject: |
Skippy wrote: | Try going to the website then pressing control then the reload button on your browser. You might be getting an old cached version of the web page. |
At the Wired website whilst looking at v3.074.2 I pressed ctrl & F5 and the page magically changed to v3.084.
I've heard of this...but don't understand
Thanks Skippy  _________________ Garmin C320 & Garmin Quest |
Posted: Fri Sep 02, 2005 12:16 pm Post subject: |
DPL wrote: | At the Wired website whilst looking at v3.074.2 I pressed ctrl & F5 and the page magically changed to v3.084. |
Ahhh. When you hit a web page your browser saves a copy of the page on your hard disk. If you return to the page, it uses some smoke and mirrors to figure out if you already have a copy of the web page and it can do one of several things including:
Use the cached version (which is what happened) OR Check for a new version and download it if it has been modified (which is what should have happened).
All's well that ends well. 8) _________________ Gone fishing! |
HDRW Lifetime Member
Joined: Sep 04, 2005 Posts: 18 Location: St.Albans, Hertfordshire
Posted: Sun Sep 04, 2005 6:09 pm Post subject: |
Wired,
Thanks for putting in the effort - it's a great benefit to us of the Great Unwashed! I just loaded it into my trusty StreetPilot III, and on a quick look the red blobs do tend to blend in with the colour of main roads a bit - I'll report back when I've used it on the road in anger, and if it is a problem I'll try the orange option.
I've always used the "Scenic" icon for cameras that I've marked myself (because it's a stand-out cyan in colour, and it's a camera symbol!) so it will take a bit more careful watching of the screen to spot your blobs, I think.
I have to say I found the instructions on using Mapsource a bit sparse, and it took me some time to work out what to do to add your "map" to the list, but I got there in the end!
Thanks again!
Howard |
GDW Occasional Visitor
Posted: Fri Sep 09, 2005 3:25 pm Post subject: |
how long is it taking everyone to install this application? to a quest to be more precise. |
Posted: Fri Sep 09, 2005 4:32 pm Post subject: |
about 5 seconds once I realised. |
blakeroad Occasional Visitor
Posted: Tue Sep 27, 2005 9:48 pm Post subject: |
WiRED I've just downloaded the camera dBase a Garmin GPSMap 276C and it worked a dream.
You are truely gifted :D
Smoothly through the installer, map source and onto the unit via USB to it's memory/storage card (not sure which it ended up on).
Thank you for offering the help that Garmin fail to! Great tool
My next adventure is to get the proximity alerts working, if i work it out I'll post it.
Graham |
missing_user
Posted: Tue Sep 27, 2005 10:57 pm Post subject: |
blakeroad wrote: | My next adventure is to get the proximity alerts working, if i work it out I'll post it.
Graham |
To get the 'proximity alerts' to work from the 'overlay' will be of great interest!!???
Is it possible? |
WiRED Regular Visitor
Joined: Apr 01, 2005 Posts: 125 Location: Berkshire, UK
Posted: Sat Oct 01, 2005 8:07 pm Post subject: |
The Safety Camera POI map for Garmin GPSRs has now been updated to v3.094 of the database.
It can be downloaded from:
http://myweb.tiscali.co.uk/walterwright
/WiRED |
Almahadeus Frequent Visitor
Posted: Sat Oct 01, 2005 8:40 pm Post subject: |
Many thanks Wired. Great as ever. |
Bobbie009 Occasional Visitor
Posted: Mon Oct 17, 2005 12:11 pm Post subject: Some questions |
WIRED
I agree with HDRW about the colour and was thinking of trying the orange myself. Like him I previously used the scenic cyan coloured camera symbol on my SPIII which is really clear.
I have a question which may sound stupid; you say the overlay is transparent. On my Mapsource European City Navigator 5 I can either view the normal map or I can view the camera sites but only on a white background with no mapping. When I download to my SPIII I can only see the camera locations when the scal is set to 0.8 miles or lower. Do I have a glitch somewhere or is this normal.
Finally how do you inform someone about cameras that are not on the overlay ie new ones?
Sorry this seems a bit whingy but let me assure you that the work you are doing is really brill. |
Posted: Tue Oct 18, 2005 1:39 pm Post subject: |
Hi BOBBY009,
Glad you like the map.
The transparency feature does only work on a GPS, and not with MapSource. With MapSource you have to select your map product to display, and there's no way to select more than one. So, no, you are doing it right.
I did set the map to not display the cameras at less than a certain magnification, otherwise all you see is a screen full of red dots and you can't work out where you are. On my Streetpilot 2610 I can control the amount of Map Detail with a menu setting. In "Normal" mode the cameras are displayed at 12m zoom, but not at 20m or higher. I can change this Map Detail setting from Normal to Less, Least, More or Most. I don't know if the SPIII has an equivalent setting, but if it has, you can use this to control when the cameras appear.
To get new cameras added yto the map, submit them to PocketGPSWorld using their normal procedures. I get a fresh database from them every month, and create the map from that.
WiRED |
Posted: Wed Oct 19, 2005 5:09 pm Post subject: Reply to WIRED |
WIRED
Thanks for your reply. I tried changing the detail on my SPIII from more to most and this enabled me to see the camera locations at 1.2 miles but no further. This is an improvement on the 0.8 miles I had previously. I will send a few new camera locations to the PocketGPSWorld site as you suggested. By the way have you considered changing the colour of the red gatsos as they merge into the red roads at the scale the SPIII works on? (Cyan would be good) |
Posted: Thu Oct 20, 2005 1:28 pm Post subject: Re: Reply to WIRED |
Bobbie009 wrote: | By the way have you considered changing the colour of the red gatsos as they merge into the red roads at the scale the SPIII works on? (Cyan would be good) |
When making the map I have to choose from a table of existing Garmin Points of Interest. I currently use nautical beacons as they would be unlikely to be used for anything else on a road map. There is no such thing as a cyan beacon. Only around 7 colours are available, and I can't use yellow, white, black or violet as they disappear against the background, at least on the 2610, Quest and some other units I have seen. I've played with various options and red or orange seem to work best on most units. Can you send me a screenshot of your SPIII? E-mail it to "walter dot wright at gmail dot com" if you can.
/WiRED |
