GrahamCresswell Occasional Visitor
Posted: Fri Sep 09, 2005 1:02 pm Post subject: TT5 position error |
I've installed TT5 on my PDA and I'm driving it from a Bluetooth GPS that I got off eBay. The indicated position on the map is consistently about 200 yds NNE of the true position. When I'm moving N or S the position is generally shown on the road that I'm actually on but if I'm moving E or W, the kit thinks I'm in a side street and is constantly re-navigating to get me back on to the main road. I can set different spheroids on the GPS but it doesn't seem to influence the result. Is there a way of introducing an offset into the TT5? Can anyone suggest another solution? |
![](modules/Forums/images/avatars/32928398450ec149ec6abd.gif)
Joined: 30/12/2002 17:36:20 Posts: 4914 Location: Oxfordshire, England, UK
Posted: Fri Sep 09, 2005 1:07 pm Post subject: |
Hi GrahamCresswell,
to the forum!
If you can set different spheroids on the GPS, can you set a different Map Datum? If you can, try Map Datum WGS84.
Garmin Camper 770 LMT-D |
Posted: Fri Sep 09, 2005 1:21 pm Post subject: TT5 position error |
Sorry Privateer - that's what I call a spheroid. I've tried WGS84 and OSGB36 because they are the most commonly used datums as far as I am aware. Neither solves the problem.
Graham |
Posted: Fri Sep 09, 2005 1:35 pm Post subject: |
Hi Graham,
That’s OK. ;) However I would stick with WGS84 though as that’s what the vast majority of electronic maps use, including TomTom ones.
If you’re able to change Map Datum and spheroids ;), do you have any other parameters that you can change? E.g. offsets?
What GPS unit are you using?
Posted: Mon Sep 19, 2005 10:18 am Post subject: |
I'm using a Bluetooth GPS receiver that I got from eBay. It doesn't have a brand name and the supplier was a chap in Hong Kong! Perhaps I am getting my just deserts! |
floody Regular Visitor
Posted: Mon Sep 19, 2005 1:41 pm Post subject: |
Graham,
I'm using a BT-338 device & I don't get any errors on mine & I'm pretty sure that the majority of users don't either.
How's the Fant Footy going!!! |
gekko Occasional Visitor
Posted: Mon Sep 19, 2005 2:16 pm Post subject: |
I'm using the Holux GR-236 and I'm getting the same bug/issue. Not very often though, it has occured three times on three different locations and times of the day. In my cases the problem went away after 10-15 minutes. No idea why it happens. It's really irritating though....
Can you reproduce the error, i.e. do you get the error everytime you drive a certain street/location? |
